02 4.7 liter change to 03 4.7 liter engine swap #148448
11/10/08 04:05 PM
11/10/08 04:05 PM
Anonymous OP
Anonymous OP
I was wondering if it is possible to change an 02 4.7 liter to 03 4.7 liter by changing cams or something to get it back to the 16 teeth instead of 32, Thanks
Re: 02 4.7 change to 03 4.7 liter #148449
11/12/08 02:43 AM
11/12/08 02:43 AM
Anonymous OP
Anonymous OP
Would you be so kind as to enlighten me on the teeth that you are referring to?
Re: 02 4.7 change to 03 4.7 liter #148450
11/13/08 01:27 PM
11/13/08 01:27 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
the 16 and 32 tooth gear is on the crankshaft,it can be swapped,but you have to remove the crank to do it,or so im told
butch
Re: 02 4.7 change to 03 4.7 liter [Re: rhad] #148451
11/14/08 02:00 PM
11/14/08 02:00 PM
Anonymous OP
Anonymous OP
I was thinking it was on the cams I have had hell with this motor just replaced drivers side head 40k ago and now I think I lost the motor this time.Crank and cams are in good shape on 02 motor I guess I need to find out if they will interchange with 03 motor, Thanks for the help Darrin
