We had a new gear set made but it is not in the car yet
The new gear set has 195 1st gear and 135 2nd gear then I could use all three gears and kill the violence and make it more like a glides low gear which is usually 180 ...
We will be testing this set up next season...
Mopar to the front
Where did you get the gears and how pricey were they? I need to do that or switch to a glide.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
