Steering wheel won't return to center...
#1484189
08/13/13 10:35 PM
08/13/13 10:35 PM
Posts: 2,190 SW MO
closer9
SW MO
Okay, I've been chasing this for a while now. Keep hearing it has to be alignment or ball joints or steering column alignment or...
Well, I've checked everything, and everything looks good, so knowing that this problem came about after I swapped out the yet another parts store steering box I decided to see what happens when I take the power steering pump belt off, and found that other than losing the assist everything went back to normal, and the steering wheel centered itself.
Anyone heard of this happening before? I've learned my lesson with parts store boxes, but I'm just wondering is there any way I could have screwed this up?
I haven't decided what to do just yet. Thinking about Firm Feel Stage 2, but just don't really have the money to spend on that right now. Would love to go AlterKation, but well...
Just for the record you can turn the wheel to any position and it will stay right there regardless... up/down hill, over bumps, etc...
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
Re: Steering wheel won't return to center...
[Re: RapidRobert]
#1484192
08/13/13 11:23 PM
08/13/13 11:23 PM
Posts: 2,190 SW MO
closer9
SW MO
I've already loosened the adjustment one full turn with no effect. I can go more, but not sure it will do anything.
and I don't think the valve needs adjusting. From what I understand that only centers the steering if you have "tool much" assist in either direction. That's not my problem. I can jack up the front, start the car and turn the wheel lock to lock stopping anywhere along the way, and it will stay put. Same thing happens when driving. Not any tighter towards the center or near either lock.
[Re: stumpy]
#1484194
08/14/13 12:07 AM
08/14/13 12:07 AM
Posts: 2,190 SW MO
closer9
SW MO
I would think if the gear box was too tight I would have the same issue when the pump wasn't being driven. My driveway has washed out some in front of the garage leaving a roughly 4" drop. With the pump driving I can back out while turning and the wheel stays put. When I pulled the pump belt and tried again it almost pulled the wheel out of my hand while backing out.
[Re: closer9]
#1484196
08/14/13 12:58 AM
08/14/13 12:58 AM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Well, I've checked everything, and everything looks good, so knowing that this problem---- What problem---? came about after I swapped out yet another parts store steering box I decided to see what happens when I take the power steering pump belt off, and found that other than losing the assist everything went back to normal, and the steering wheel centered itself.-----so the steering wont center it self----? Anyone heard of this happening before? I've learned my lesson with parts store boxes, but I'm just wondering is there any way I could have screwed this up?
---so the steering will not stay centered with power assist---?
[Re: ek3]
#1484198
08/14/13 01:14 AM
08/14/13 01:14 AM
Posts: 2,190 SW MO
closer9
SW MO
Maybe I'm not explaining it clearly.
So here was my first test that made me think it is the steering box.
Start the car drive it down my bumpy hill turning wheel lock to lock. Never once did the wheel try to center itself or even move from where I put it.
Backed up to top of hill, turned engine off, put car in neutral, rolled down hill and steering centered itself just like any other car would.
[Re: closer9]
#1845322
06/09/15 10:01 PM
06/09/15 10:01 PM
Posts: 2,190 SW MO
closer9
SW MO
Figured I'd bring this back from the dead, since I never figured it out. Just left the car parked till I recently decided to sell. Had tried another steering box a friend loaned me. He bought it as a core, but turned out to be rusty inside and worse than what I had. I needed to put my old box back in, so decided why not try one more parts store warranty box. After waiting 2 months for them to find one, it's no different than the previous.
I've read up as much as I can find on the issue online. Seems there are others out there with the same problem, but if they find an answer they never reply.
Just out of curiosity, I pulled the spool out of the control valve thinking maybe it was bad and blocking flow, but it didn't change anything. As I'm typing this though, starting to wonder how that circuit is run. Can the problem be fluid flowing back and equalizing pressure somehow. Can't seem to find a circuit diagram for these. There is a cutaway in the service manual, but I'm either too stupid to figure it out, or it doesn't give enough info.
Just for those that may not want to read up to this point. I swapped a steering box a while back, and now my steering will not return to center. I am unable to jack the car up and turn the wheels by hand while it is running. I can however, pull the steering pump belt, and get somewhat normal function.
I think I have guy coming to look at the car this weekend. I figure if I haven't sold the car by fall I'll call up Firm Feel and order one of their boxes. Maybe run the issue by them before I do. Make sure there isn't something stupid I'm doing to cause this that would affect their box as well.
Just very frustrated...
[Re: mikemee1331]
#1846527
06/11/15 11:51 AM
06/11/15 11:51 AM
Posts: 2,190 SW MO
closer9
SW MO
this is exactly where i'm at. wheel won't return to center, wants to wander while driving it. works ok in 'beast' mode (belt off). i've been fiddling, and fiddling with that valve location, nothing except i've stopped the wheel from turning on its own at a stop. amazingly frustrating and the FSM is little help. and the carpenter bees didn't help! PLEASE let me know if you find out something from Firm Feel. my next step is to rebuild my lower control arms and the steering coupler. why? i don't know what else to do. it was a working unit until the original pump went south and now i'm not so sure i ever had a problem with that one! I'm sorry to hear about your situation, but it's somehow a huge relief to actually hear from someone with the same problem. I've got one more trick I want to try before I give up and contact Firm Feel. Just not sure when I'll be home long enough to try it.
