Re: What went wrong? flex plate, converter, or tranny?
[Re: 71nonRT340shaker]
#1483606
08/15/13 12:13 PM
08/15/13 12:13 PM
Challenger 1
Cincinnati, Ohio
Take a screwdriver and check the crank end play, do it between the flex plate/crank flange and block and then damper and timing cover.
#1483612
08/16/13 09:35 AM
08/16/13 09:35 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Will do I talked to John at ATI racing yesterday. I'm going to send out the converter which btw doesn't have any weights on the outside of it. I'm planning to order a new flex plate/bolts, shumacher motor mounts and with any luck it will be good to go.
If you put that thing back in Bill's basement you won't have to worry about it !! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: 62maxwgn]
#1483613
08/16/13 09:49 AM
08/16/13 09:49 AM
Posts: 116 Pa
71nonRT340shaker
Pa
Haha this is my 70 'cuda that came out of the Snow Shoe area, the challenger is a 4 speed car...
