Page 3 of 3 1 2 3
Re: What went wrong? flex plate, converter, or tranny? [Re: 71nonRT340shaker] #1483600
08/15/13 10:53 AM
08/15/13 10:53 AM
SE PA
Yellow Fever Offline
SE PA
Where in PA are you? Go to Pat's Convertors, they will check it out.
Pat's Converters Inc
101 Swarthmore Ave
Folsom, PA 19033
(610) 237-6900
Re: What went wrong? flex plate, converter, or tranny? [Re: Yellow Fever] #1483601
08/15/13 11:14 AM
08/15/13 11:14 AM
Pa
71nonRT340shaker Offline OP
Pa
I'm a stone's throw from State College, just about 8 miles east.
Re: What went wrong? flex plate, converter, or tranny? [Re: 71nonRT340shaker] #1483602
08/15/13 11:27 AM
08/15/13 11:27 AM
SE PA
SE PA
That's a drive then, they are by me in SE PA, just south of Philthy!
Re: What went wrong? flex plate, converter, or tranny? [Re: Yellow Fever] #1483603
08/15/13 11:40 AM
08/15/13 11:40 AM
Pa
Pa
I'll figure something out, I was beat last night but I'm not giving up on the project yet and my DS motor mount is really spongy I can pry up on it between the k-frame and the ear that's bolted through it making everything move and twist. I'm curious to see if possibly the bottom of that bracket is rattling off the k-frame shaking the whole car when it's under a load. I'm stumped and will just take care of those few things and see if it magically goes away.
Re: What went wrong? flex plate, converter, or tranny? [Re: 71nonRT340shaker] #1483604
08/15/13 12:00 PM
08/15/13 12:00 PM
Indiana
68_661charger Offline
Indiana
The lack of a good drivers side mount will make noise when driving under a load but not necessarily when in park. I agree the convert bolts are too big and the stall on that convertor probably makes it a bear to drive??. Worst case is the crank is walking forward as the RPMs increase causing contact.
Re: What went wrong? flex plate, converter, or tranny? [Re: 68_661charger] #1483605
08/15/13 12:08 PM
08/15/13 12:08 PM
Pa
Pa
I didn't do a ton of driving before putting the trans mount in last year but it was friendly on the street, made lots of noise, left hard from lights, shifted into 3rd around 60 - 65.
There's a steep road near my house we crossed over before the trans mount and it shook the worst it ever did while climbing the mtn. Beats me, new parts will be ordered what I get paid next week and with any luck it will settle a bit.
Re: What went wrong? flex plate, converter, or tranny? [Re: 71nonRT340shaker] #1483606
08/15/13 12:13 PM
08/15/13 12:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Take a screwdriver and check the crank end play, do it between the flex plate/crank flange and block and then damper and timing cover.
Re: What went wrong? flex plate, converter, or tranny? [Re: 71nonRT340shaker] #1483607
08/15/13 04:40 PM
08/15/13 04:40 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
You might want to run the engine now and see if there is any vibration there. The more things eliminated the less you have to think about.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: What went wrong? flex plate, converter, or tranny? [Re: OldMoparMan] #1483608
08/15/13 04:45 PM
08/15/13 04:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not gonna be able to use a starter now.
Don't be the exception.
Re: What went wrong? flex plate, converter, or tranny? [Re: Supercuda] #1483609
08/16/13 12:56 AM
08/16/13 12:56 AM
Unless you have nuetral balanced stick flywheel and bellhousing to match the size of the flywheel I do OP, I hope you find the problem Let us know what you do find
Re: What went wrong? flex plate, converter, or tranny? [Re: Cab_Burge] #1483610
08/16/13 09:11 AM
08/16/13 09:11 AM
Pa
Pa
Will do I talked to John at ATI racing yesterday. I'm going to send out the converter which btw doesn't have any weights on the outside of it. I'm planning to order a new flex plate/bolts, shumacher motor mounts and with any luck it will be good to go.
Re: What went wrong? flex plate, converter, or tranny? [Re: MoparforLife] #1483611
08/16/13 09:35 AM
08/16/13 09:35 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Are the alignment dowels in the block? I don't see them in the pics.
Re: What went wrong? flex plate, converter, or tranny? [Re: 71nonRT340shaker] #1483612
08/16/13 09:35 AM
08/16/13 09:35 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you put that thing back in Bill's basement you won't have to worry about it !!
Re: What went wrong? flex plate, converter, or tranny? [Re: 62maxwgn] #1483613
08/16/13 09:49 AM
08/16/13 09:49 AM
Pa
Pa
Haha this is my 70 'cuda that came out of the Snow Shoe area, the challenger is a 4 speed car...
Page 3 of 3 1 2 3
