stupid 64 Fury heater question #1482345
08/10/13 02:57 PM
08/10/13 02:57 PM
Missouri
Dragger40 Offline OP
Missouri
The heater has been on in my Fury because the warm lever cable is laying on the floor and not hooked up on the heater box end. The question is... do I have to remove the heater box to re-hook the other end and where does it re-hook?
Am I missing something?
I hate the thought of removing the box if I dont have to.
Is it fast? It has a lightning bolt dont it?
Re: stupid 64 Fury heater question [Re: Dragger40] #1482346
08/10/13 03:33 PM
08/10/13 03:33 PM
If you mean the levers at the end of the several cables that control the doors you could get up in there & the one that is missing its' lever move the door/shaft to the other end of it's travel to shut the door. shut that one (for the floor air) then set the dash lever/knob so the defrosters up top ain't gettin any air either if you want everything shut off right now
Re: stupid 64 Fury heater question [Re: Dragger40] #1482347
08/10/13 03:52 PM
08/10/13 03:52 PM
Missouri
Missouri
I guess I'm not explaining very well.
The cable that should open the valve lets in hot water is not hooked up at the valve. It is hooked up at the control panel on the warm/cool lever.
I've looked at the box a couple times and I dont see where the other end goes so I'm assuming that I have to remove it to gain access in order to rehook.
In short: cable is attached at control lever, other end is laying in the floorboard.
Thanks for the help. I hope this clears it up a little.
Re: stupid 64 Fury heater question [Re: Dragger40] #1482348
08/10/13 07:20 PM
08/10/13 07:20 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A/C or not?
The non-A/C heater water valve is inside the car on the drivers side of the heater box. Follow the heater hoses through the firewall.
Re: stupid 64 Fury heater question [Re: John_Kunkel] #1482349
08/10/13 07:47 PM
08/10/13 07:47 PM
SW CO
HemiSportFury Offline
SW CO
You do not have to remove the heater box. As said above, the cable hooks to the valve on the ds of the heater. There is a tab on the valve that the loop on the end of the cable goes over, then there is a clip that secures the cable sheath, as I recall. Not hard to do.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: stupid 64 Fury heater question [Re: HemiSportFury] #1482350
08/10/13 08:31 PM
08/10/13 08:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its hard to see but its by the gas pedal.If its like the 65 I have the valve might be had to move.Mines been off at the control for years after the cable bent.I just lay on the floor and move it by hand.The cable should have a round wind on the end IIRC.It slips over the arm and moves it.There is 1 or 2 clamps that hold the cable in place on the case I believe and or one by the control head.Rocky
Chrysler Firepower
Re: stupid 64 Fury heater question [Re: therocks] #1482351
08/11/13 08:45 PM
08/11/13 08:45 PM
Missouri
Missouri
Thanks everyone.
I've looked under the dash a half dozen times but I just wasnt seeing what I thought I should see.
Takin care of now. Thanks Moparts
