Glad to hear you got the leak fixed Mike
Even happier to hear it wasn't the filter adapter gasket
Hope the rest comes together a little easier for you
Its still sucking in oil... I'm gonna pull the intake
for a look... maybe this intake is cut wrong.. if
I dont see anything I'm gonna pull the heads and put
my W-2s and intake on
EDIT
I pulled the intake... all 4 front runners had a
stream going down each one... sucking in from the
bottom... and I had that intake cut... looks to be
cut wrong
