Question For roadhazard #1482290
08/10/13 10:39 AM
08/10/13 10:39 AM
MR_P_BODY Offline OP
Greg I need to get a new gasket set for my oil filter
adapter... on your P/N SFP-340-KS... how thick is
the larger gasket(the 4.5" one)... I'm having issues
with it sealing... seems that the center is bottoming
out without much compression on the outer gasket...
but the gasket I have is maybe .020 thick
thanks
Re: Question For roadhazard [Re: MR_P_BODY] #1482291
08/10/13 11:17 AM
08/10/13 11:17 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Material spec. is .047" Mike
Edit; the part number is 340-K5
Re: Question For roadhazard [Re: roadhazard] #1482292
08/10/13 01:16 PM
08/10/13 01:16 PM
Thanks... I went over to Mancini's and picked up 2
sets... I'm having a issue between your gasket and the
machined area on the block... the OD of the gasket is too
large or the recess in the block is machined too small..
if I try to stick it in, it wants to mound up ..
looks like one or the other is maybe .050- .075
too small or to big diameter wise... I trimmed the
OD on your gasket to get it to fit
Re: Question For roadhazard [Re: MR_P_BODY] #1482293
08/10/13 03:25 PM
08/10/13 03:25 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Mike,
Thats a common problem on the small blocks when you re-use the oil filter diffuser plate, the center of the plate, where the thru bolt goes, after time, looses its tension, and goes from a convex posture, to a concave posture. Its the only thing really putting pressure on the gasket to seal it . You can flip them over, take a solid shaft ( aluminum scrap) and press them backwards about .050-.060, and it will put some prelaod back in it. If you push it .050, it will relax back about half that.
The other obvios solution is use an aftermarket solid plate, whis is much much better.I'm fortunate, as I have a ton of those plates around from teardowns, and I'd say about half of them dont prelaod the gasket well without tweaking. For the most part now, unless its a super duper budget deal, I just replace with a new Canton and make life easy...
RIP Monte Smith
Re: Question For roadhazard [Re: MR_P_BODY] #1482294
08/11/13 10:17 AM
08/11/13 10:17 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Mike, I'll see if I can round up my old 340 block and get a measurement of that area.
Thanks for the feedback
How did everything else work out for you with that kit?
Re: Question For roadhazard [Re: roadhazard] #1482295
08/11/13 10:30 AM
08/11/13 10:30 AM
Does the small thick one go under the plate and the small
thinner one under the hex head.... I couldnt use the
small thicker one.... but its sealed up now
Re: Question For roadhazard [Re: MR_P_BODY] #1482296
08/11/13 10:37 AM
08/11/13 10:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I bet the small thick one is only used for the factory adaptor.
68 Barracuda Formula S 340
Re: Question For roadhazard [Re: Bad340fish] #1482297
08/11/13 10:49 AM
08/11/13 10:49 AM
I bet the small thick on only used for the factory adaptor.
I'm running the factory plate
Re: Question For roadhazard [Re: MR_P_BODY] #1482298
08/11/13 10:54 AM
08/11/13 10:54 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Me too, I don't miss the adapter one bit.
Re: Question For roadhazard [Re: MR_P_BODY] #1482299
08/11/13 11:45 AM
08/11/13 11:45 AM
Syracuse,NY
Syracuse,NY
Thats correct Mike. Thick one is used to seal between adapter and block when your using the thru bolt sytle adapters.Thin one goes under hex head. If its just a plate and the threaded oil filter adpater, ( filter direct to block) , then not needed.
RIP Monte Smith
Re: Question For roadhazard [Re: MR_P_BODY] #1482300
08/11/13 02:49 PM
08/11/13 02:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Hey, your the small block guy!!
But yes, that's the order of install.
Guess I need to find out what my Father did with that complete 340 I gave to him 10 years ago
Re: Question For roadhazard [Re: roadhazard] #1482301
08/11/13 03:26 PM
08/11/13 03:26 PM
Thats the way I put it but wanted to make sure...
I have to pull it back off... it still has a SMALL
drip going on... plus the stupid foam intake is leaking
(or it could be the sender)... I'm gonna check the
sender first then the intake... just to make sure
its not dripping down the back of the block....
this car HATES ME... but it runs good.. LOL
Re: Question For roadhazard [Re: MR_P_BODY] #1482302
08/12/13 11:02 AM
08/12/13 11:02 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Right on Mike..... I know that thing has been giving you fits
Hope it's just the sender and an easy fix for you
I'll check some dimensions soon as I can get to it
Re: Question For roadhazard [Re: roadhazard] #1482303
08/12/13 11:12 AM
08/12/13 11:12 AM
I cleaned it last night and fired it up to see.. it
looks like I have 2 leaks... the filter base and the
intake foam rubber... I'm headed out in a few to
pull the intake and the filter... I'm gonna cut a
.062 thick gasket for it... being I had to stack 2
intake gaskets for this block I thought that the foam
was thick enough.. well it wasnt... I dont normally
use those foams and just silicone it but it looked
like a pretty big gap to silicone so I'll fix the rear
foam with a thicker foam and some Right Stuff
Re: Question For roadhazard [Re: MR_P_BODY] #1482304
08/12/13 04:57 PM
08/12/13 04:57 PM
Syracuse,NY
Syracuse,NY
If you have time, make some aluminum spacers and get rid of any of the foam. Countersink some screws and never a problem again.
RIP Monte Smith
Re: Question For roadhazard [Re: CompWedgeEngines] #1482305
08/12/13 05:10 PM
08/12/13 05:10 PM
I pulled the intake today and seen oil was running
under the foam rear gasket... I redid it with Great
Stuff on the block then put the foam on.. and let
that set up.. then used silicone on the top of the
foam then set the intake on and bolted it down.. then
let that set up... I fired it up a few minutes ago
and everything looks dry now... I only ran it 3 to
5 minutes but it was all dry... I'll let it totally
dry and take it out tomorrow and heck it again... but
I think it was the intake issue... I HOPE...I want
to hit Woodward tomorrow if its sealed up
Re: Question For roadhazard [Re: MR_P_BODY] #1482306
08/13/13 06:27 PM
08/13/13 06:27 PM
It was the rear intake gasket causing all the oil leak...
all better now.. took it out for a 50 mile run today
Re: Question For roadhazard [Re: MR_P_BODY] #1482307
08/13/13 09:43 PM
08/13/13 09:43 PM
ohio
all spooled up Offline
ohio
good deal
Re: Question For roadhazard [Re: all spooled up] #1482308
08/13/13 09:50 PM
08/13/13 09:50 PM
good deal
Thanks... still trying to get the oil out of the muffs..
I drilled a 1/8" hole in each to get it to drip out
and the exhaust will help blow it out
Re: Question For roadhazard [Re: MR_P_BODY] #1482309
08/14/13 11:21 AM
08/14/13 11:21 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Glad to hear you got the leak fixed Mike
Even happier to hear it wasn't the filter adapter gasket
Hope the rest comes together a little easier for you
