Small block cam bolt question. Oil hole. #1482268
08/10/13 04:56 AM
08/10/13 04:56 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
My 76 360 has a bolt with an oil hole in the upper left thrust plate.
79 360 doesn't. It had a solid bolt with an oil slinger on the bottom.
I broke the one with an oil hole.
Is it absolutely necessary to have this bolt with the oil hole? Where do I find one? I drilled one out but that leaves me short on the next motor.
Can I use the bolt with the hole AND the oil slinger?
Re: Small block cam bolt question. Oil hole. [Re: magnum440d100] #1482269
08/10/13 08:56 AM
08/10/13 08:56 AM
scratchnfotraction Offline
it does not have to have the oil hole in the bolt.
oil slinger on the crank if you have it.
you also want the metal dip tab that goes on the lower thrust plate bolt.
I have not run one with a oil hole in the bolt for yrs.
I just use the drip tab and oil slinger.
Re: Small block cam bolt question. Oil hole. [Re: magnum440d100] #1482270
08/10/13 09:25 AM
08/10/13 09:25 AM
Is it absolutely necessary to have this bolt with the oil hole? Where do I find one? I drilled one out but that leaves me short on the next motor. Can I use the bolt with the hole AND the oil slinger?
(1) I would (2) jy but see #3 (3) redrill another grade 8 bolt (1/8" hole) (4) absolutely & that's better yet
Re: Small block cam bolt question. Oil hole. [Re: RapidRobert] #1482271
08/10/13 01:12 PM
08/10/13 01:12 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I use it and actually drill the hole next size bigger, the chains wear on sb!
Re: Small block cam bolt question. Oil hole. [Re: ademon] #1482272
08/10/13 01:28 PM
08/10/13 01:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I don't think it'll help. I had a factory oil cooler setup on my 87 Diplomat, 318 later 360. The cooler taps off the hole where the sending unit is, routes the oil thru the cooler then discharges into the timing cover thru a rifle drilled fuel pump mounting bolt, right into the chain. It didn't help with timing chain wear.
Don't be the exception.
