gravity bleed front disc brakes??
#1482143
08/09/13 03:28 PM
08/09/13 03:28 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Can has been.setting for few years now and after got car running again decided to bleed brakes... first was no fluid (setting 4-5years) so top off mc went to passenger side front got my mighty vac ..hooked up and cracked the line after pumping up and.cracking line and really still no progerss i took bleeder out and was bone.dry. with bleeder out i pumped brakes and.fluid would come out so decided to just leaver the bleeder out till fluid came out after few hours still nothen...???whats the deal??
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: gravity bleed front disc brakes??
[Re: stumpy]
#1482145
08/09/13 03:59 PM
08/09/13 03:59 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Top is off...no i didnt open the other bleeder.......should i crack it open or take it out??
[Re: stumpy]
#1482147
08/09/13 04:42 PM
08/09/13 04:42 PM
RapidRobert
See if your prop valve has a little pin & if so pull it out & hold it out with a pair of vice grips then rebleed
[Re: RapidRobert]
#1482148
08/09/13 05:26 PM
08/09/13 05:26 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Had the wife help me so there good now still no clue why the passenger side would not leak out... i took bleeder out of the driver side and fluid started dribbling out of it went checked pass side....nothen..
