Cam fit too tight, but its okay now.
#1481850
08/08/13 11:49 PM
08/08/13 11:49 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Hey guys, I'm swapping cams in my 440/493. The 292/509 is out and the Lunati 316/326 is going in....sorta. With the cam going in, its fine until the last 1/2 inch. From there, it gets tight. With a cam sprocket on, it takes about 25 lbs or more of torque to spin the cam. I tried it with the '509 and it spins with just a little effort. Its not as if it rotates freely like a wheel bearing with the '509 though. I have about 3000 miles on this build. None of the bearings are nicked. They are all in right with the oil holes pointing down. The '509 cam shows no hot spots or irregular wear. After putting the Lunati in and spinning it, it still looks the same as well. I measured the journals of both cams.
# Lunati..... 509 5 1.75..... 1.74 4 1.95..... 1.94 3 1.96..... 1.96 2 1.98..... 1.98 1 2.00..... 1.99
The slightly larger #1 and #5 journals is the only thing that looks out of whack. Can .01 difference be enough to cause this?
Re: Cam fits too tight!
[Re: Kern Dog]
#1481851
08/09/13 12:21 AM
08/09/13 12:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You should be measuring closer than 2 decimal points.. even at 3 points its some time not good enough.. if you turn the cam around and check the front bearing you can touch that journal with fine paper... if its the rear its a bit harder to do
[Re: Kern Dog]
#1481853
08/09/13 12:50 AM
08/09/13 12:50 AM
MR_P_BODY
Turns out the 'tight cam" is a pretty common thing. This is the first I have heard of it. Sorry about the "less that precise" numbers. My cheap ass dial calipers only go to two points past the decimal! Looking through the archives, I have read the following ideas: * Take a junker old cam and cut a groove in the journals. Install the cam and spin it slowly. The groove will take down any high spots. * Take a junker old cam and install it. Tap it at the 12:00 position, 6:00, 3:00 and 9:00, then spin the cam 180 degrees and repeat.
With the engine still in the car, I hesitate to try the first method. I can't imagine that it is a good idea to allow bearing shavings to fall onto the rods and crank. I read that one guy put bearing grease in the groove to collect the shavings.
I have a old cam that I cut the grooves in.. if its in the car I grease the grooves to hold the shavings... if it gets down to the bottom the pump will push it through and the filter gets it... this is pretty normal on mopars... I have never had a cam spin freely with out some work
[Re: Kern Dog]
#1481856
08/09/13 10:58 AM
08/09/13 10:58 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
I thought about that. It binds during a full rotation, not just during part of it. My common sense tells me that a cam with a bend in it might be tighter at one point than another.
, the cam is probably bent , would be real easy to check in a lathe .
[Re: JohnRR]
#1481857
08/09/13 04:42 PM
08/09/13 04:42 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
You have an extra cam laying around you can do the groove thing with, like what Mr P Body was saying? That sounds like the best solution, looking at your measurements I don't think you need to remove much material from the bearings
[Re: ntstlgl1970]
#1481858
08/09/13 04:53 PM
08/09/13 04:53 PM
Posts: 4,179 California
mickm
California
i agree. groove the cam slightly, and line the groove with some grease, but don't fill it all the way. the amount of material you need to remove from the bearing is minimal, and it is bearing material, not hard metal. then wipe down the cam bearings as best as you can, and then off you go.
but still, first choice would be to take it to a machine shop and have them polish the journals. have them measure both cams with a mic (as stated) so you know what they really are. taking off .001 is nothing. if they do that, then you can take it home and compare. if it fits, you're done. if not, you'll have a good idea of the change, and then can go back for more.
i would go that route first, but then my machine shop is 2 miles from my house!
[Re: Kern Dog]
#1481862
08/13/13 04:02 AM
08/13/13 04:02 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
I degreed the cam today. It was my first time doing it, so let me know what you think. I was having a hell of a time at first. The engine was very hard to spin over and I bent the piston stop twice. After I removed the plugs, it spun over easy enough to feel the piston stop when I reached it. I came up with a 110 number. The cam card shows a 108 LSA with an installed centerline of 106 degrees. I guess this means that I am 4 degrees retarded, right? Tomorrow I'll move the crank gear to the 4 degree ADV setting and recheck the numbers.
You are two degrees retarded now in relationship to having the cam installed straight up, (intake loe center is 110 ATDC, exhaust lobe should be 106 BTDC ),4 degrees retarded (away from ATDC,after top dead center) from what the cam makers suggests that you install it at Let us know what you get with the sprocket change
[Re: Kern Dog]
#1481863
08/16/13 11:15 AM
08/16/13 11:15 AM
JohnRR
You should have definitely pulled all the plugs out first ....
[Re: JohnRR]
#1481864
08/16/13 08:06 PM
08/16/13 08:06 PM
Posts: 15,487 Florida
scratchnfotraction
NOW! he knows..? is, will he remember it next time he degrees in a cam?
[Re: 340SHORTY]
#1481866
08/17/13 12:49 AM
08/17/13 12:49 AM
JohnRR
usally easier to degree a cam with just the #1 rod/piston installed..
That works when engine is being first assembled , but doing a swap to an engine that was running , not so much
