Re: Tranny won't come out of 1st gear [Re: John_Kunkel] #1481503
08/10/13 03:15 PM
08/10/13 03:15 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
How do I do that? Do I plug a gauge into it somewhere?
Re: Tranny won't come out of 1st gear [Re: tcat446] #1481504
08/10/13 03:25 PM
08/10/13 03:25 PM
there's a NPT plug in the case back there by the extension housing junction I believe. Not sure how high of a psi gauge you need
Re: Tranny won't come out of 1st gear [Re: RapidRobert] #1481505
08/10/13 07:13 PM
08/10/13 07:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The governor pressure test port is in the tailhousing. (7/16" hex plug)
Hook a gauge to the test port, with the engine idling in Drive the pressure should be no more than 2 psi with the tires not moving, with the tires moving it should increase with tire speed.
