Seat Belt Cleaning? #148094
11/10/08 09:48 AM
11/10/08 09:48 AM
Northern VA
bulletpruf Offline OP
Northern VA
Fellas -
My seatbelts are in sorry shape. Dirty and crusty. I'm not going to pay $1000 to get them cleaned, but any recommendations? Just warm soapy water and a brush or should I run them thru the washing machine or dishwasher?
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Seat Belt Cleaning? [Re: bulletpruf] #148095
11/10/08 10:47 AM
11/10/08 10:47 AM
So.IL.Home of Popeye
P
plum340demon Offline
P
Simple green sprayed on them and go to the car wash.Worked good for me.
Re: Seat Belt Cleaning? [Re: plum340demon] #148096
11/10/08 11:20 AM
11/10/08 11:20 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have had good success cleaning them up in the kitchen sink. i usually use dish soap and simple green. If you have oxidation on the chrome use a scotch brite very lightly and some chrome polish.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Seat Belt Cleaning? [Re: 70gtx440dana] #148097
11/10/08 11:46 AM
11/10/08 11:46 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I hand washed with dish soap and then did a couple of rinse only cycles in the dish washer (no soap). Came out great!
Re: Seat Belt Cleaning? [Re: bulletpruf] #148098
11/10/08 11:47 AM
11/10/08 11:47 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I just fill a 5 gallon pail with hot water and laundry soap and let 'em soak - stir with a stick or spoon now and then. Expect the color to bleed out of them a bit - black may come out as a really dark green, blue, a bluish white. If you're brave you can try dying them with Rit fabric dye but I'd wash after that to remove any dye that might seep out onto your clothes over time. I usually work the buckles off them, strip the paint and repaint them.
Re: Seat Belt Cleaning? [Re: Sixpak] #148099
11/10/08 11:58 AM
11/10/08 11:58 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I cleaned mine with a pressure washer. I was really
surprised at how good it worked. I saw someone
above posted the car wash, I bet that would work
great also. They are nylon, so short of something
acidic it's hard to ruin them. I have used a vinyl
die on some also to brighten them up, but they are
in the back and rarely used.
Re: Seat Belt Cleaning? [Re: Sixpak] #148100
11/10/08 12:06 PM
11/10/08 12:06 PM
Tennessee
Chatt69chgr Offline
Chatt69chgr  Offline
Tennessee
How do you get the buckles off?
I cleaned mine in a bucket with soapy water and a hand cleaning brush as suggested above. I also redyed mine using rit dye. The secret is to warm a pail of water up to 175 degrees, clean and wet the belts first, then put in pot and stir occasionally for 30 minutes, rinse off in lukewarm water then cold water. Used a packet of the black and half packet of the scarlet (was doing a blue belt on that run---black belts---just used black--all per RIT website). Messes up the paint on the buckles. Had to repaint them. Got rust off a few places using my dremel moto-tool. Just painted over the rust area with some silver paint. Most of these places were in inconspicuous places. Never could fugure how to get the buckle off the belt itself. The dye will also dye the translucent plastic slide. No way to avoid this. Did have to experiment with different paint until I got one that matched the original finish. Don't recall what that was unfortunately. Note that PG Classics and I think BEA now have reproduction belt sets available if you needed all of them. Like potato chips though, you can't buy just one belt. Sometimes you can get lucky and find a belt out of another Mopar product that can be redyed and used.
Re: Seat Belt Cleaning? [Re: Chatt69chgr] #148101
11/10/08 12:13 PM
11/10/08 12:13 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
You can work the buckles off past the stitched together ends - though your fingers will be sore afterwards.I am referring to 1970-vintage belts and metal buckles, not sure on newer ones that might have molded plastic components. It can be done. The pinch rollers are spring loaded - if you work them back with a screwdriver and hold them back you can get the belts off. Just take pics to help with reassembly, and pull plenty of slack in the loops of the pinch rollers.
Re: Seat Belt Cleaning? [Re: bulletpruf] #148102
11/10/08 01:41 PM
11/10/08 01:41 PM
Northern VA
Northern VA
Fellas -
Thanks for the info. I have a pressure washer that I rarely use, so maybe I'll drag it out and fire it up.
Thanks again,
Scott
Re: Seat Belt Cleaning? [Re: bulletpruf] #148103
11/10/08 01:53 PM
11/10/08 01:53 PM
Kirkland, Washington
Pacnorthcuda Offline
I boiled mine and did the Rit Dye thing---Huge difference. Mine are black. If you use a cup of salt in the mix with the dye it makes it 'colorfast' so it won't bleed on your wife's favorite pants and ruin YOUR day. But rinse IMMEDIATELY when you take if off the stove (boil again in rinse water as I recall) and blow dry all the metal immediatley to prevent corrosion.
I then repainted the buckles.
Re: Seat Belt Cleaning? [Re: Pacnorthcuda] #148104
11/10/08 06:19 PM
11/10/08 06:19 PM
I wrapped mine in a towel (ends and all) and put them in the washing machine. Came out looking like new. ...even the chrome!
Re: Seat Belt Cleaning? [Re: Chatt69chgr] #148105
11/10/08 07:00 PM
11/10/08 07:00 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I used Oxy Clean and dish soap let them soak in the bath tub
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Seat Belt Cleaning? [Re: 340SIX] #148106
11/10/08 11:47 PM
11/10/08 11:47 PM
MO
cdp Offline
cdp  Offline
MO
I guy here on moparts restored my seat belts for $375. That included new webbing and repainted buckles. Chroming may have been extra. Can't remember his name, but I stored his cell phone # if your interested. I think he was out of Kentucky.
Re: Seat Belt Cleaning? [Re: cdp] #148107
11/11/08 10:02 AM
11/11/08 10:02 AM
Northern VA
Northern VA
I will see what they look like when I'm done, but $375 sounds reasonable, especially when you consider what Snake Oil charges. Please e mail or pm me with his phone number.
Thanks,
Scott
Re: Seat Belt Cleaning? [Re: bulletpruf] #148108
11/11/08 01:22 PM
11/11/08 01:22 PM
Washington
69440 Offline
69440  Offline
Washington
I can restore your seat belts. We use all new webbing, completely restore the buckles, strip and replate the floor mounting hardware, correctly match the stitching, and even restore the bolts and supply new part number tags. The webbing is the correct 4-bar, polyester webbing. You pay shipping coming, and I pay shipping going. We also do not use any reproduction parts, and are saftey certified in the manufacturing of seat belts $450.00.
Upholstery Mods & More
Specializing in mopar seat belts and seat covers.
310 Crest Dr.
Shelbyville, Tn. 37160
931-680-1167 hm & shop, 253-230-7169 cell
beewagon69@yahoo.com
