Valve stem retainer and locks #1480722
08/06/13 08:45 PM
08/06/13 08:45 PM
USA
N
Nitrofish Offline OP
N
USA
Hello,
Please view the attached pictures. I recently had my cylinder heads reconditioned. All NEW parts and a valve job. I noticed that one of the valve spring keepers was not correctly seated so I decided to investigate further. I ended up removing multiple valve springs, retainers and keepers to find the same wear to all of the components. Please note that this cylinder head was never ran or even had rocker arms bolted on to it. To me this looks like used parts or possibly my old parts. Could this wear and or marks be caused by assembly of the valve springs?? Note that the wear seen to the keepers is also present as witness marks inside the retainers. All opinions are welcome
Also I measured the retainer OD at 1.500 and the valve spring OD at 1.560. Is this the correct retainer for the valve spring?
Re: Valve stem retainer and locks [Re: Nitrofish] #1480723
08/06/13 08:46 PM
08/06/13 08:46 PM
USA
N
N
USA
Pic #2
Re: Valve stem retainer and locks [Re: Nitrofish] #1480724
08/06/13 08:47 PM
08/06/13 08:47 PM
USA
N
N
USA
Pic #3
Re: Valve stem retainer and locks [Re: Nitrofish] #1480725
08/06/13 09:11 PM
08/06/13 09:11 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
they look used to me
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Valve stem retainer and locks [Re: dusturbd340W5] #1480726
08/06/13 09:14 PM
08/06/13 09:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
x2. Buy new one's, their cheap.
Re: Valve stem retainer and locks [Re: rickraw] #1480727
08/06/13 09:18 PM
08/06/13 09:18 PM
USA
N
N
USA
Retainers too or just keepers?
These are titanium, unfortunately they're not too cheap.
Thanks for taking the time to comment
Re: Valve stem retainer and locks [Re: Nitrofish] #1480728
08/06/13 09:28 PM
08/06/13 09:28 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If they look ok & the keepers fit properly, i'd run them.
Re: Valve stem retainer and locks [Re: rickraw] #1480729
08/06/13 09:40 PM
08/06/13 09:40 PM
Puyallup, WA
LemonWedge Offline
LemonWedge  Offline
Puyallup, WA
I don't know how in depth you were with your machine shop prior to work being done, but for items like keepers, if you don't specify, its not uncommon for them to have a box of used, but good pieces they may pull from.
LemonWedge - Street heavy / Strip ready.
468” Lowdeck MaxWedge - 10.42 @ 128
Re: Valve stem retainer and locks [Re: LemonWedge] #1480730
08/06/13 09:50 PM
08/06/13 09:50 PM
USA
N
N
USA
StealthWedge67,
I did ask and he agreed that new parts were going to be installed. My receipt also shows I paid for them
Thank for the input
Re: Valve stem retainer and locks [Re: rickraw] #1480731
08/06/13 10:07 PM
08/06/13 10:07 PM
Az
Crizila Offline
Crizila  Offline
Az
If he paid for new stuff he shoulda got new stuff. Pic 2 looks like retainer damage from a damper. Had to be previously run to cause that.
Fastest 300
Re: Valve stem retainer and locks [Re: Nitrofish] #1480732
08/06/13 10:11 PM
08/06/13 10:11 PM
Delray beach, Florida
P
Performance Only Offline
P
Hello,
The O.D. of the retainer is fine, it's the I.D. you need to check for both the spring (inner and outer) and the retainer.
I think you need to have a discussion with your builder as far as new vs. used.
machine shop owner and engine builder
Re: Valve stem retainer and locks [Re: Performance Only] #1480733
08/07/13 12:54 AM
08/07/13 12:54 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Those are used parts.
Re: Valve stem retainer and locks [Re: Nitrofish] #1480734
08/07/13 07:39 PM
08/07/13 07:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
StealthWedge67,
Thank for the input
Me thinks you got hosed by the shop Those are definitily not new parts You knew that BTW, if your springs have inner dampeners on the outer springs you may want to use tool steel retainers instead of the titainum ones or remove the dampeners I had one pump gas street customer that drove his car a lot have a inner dampener eat through his titainum retainers Luckily he found it before it caused any real damages to his motor
