Check the length of your driveshaft.
so what cha think that the driveshaft may be too long and stressing the sprag?
Motor might be moving to the rear a tad when that trans brake button is released. Do you have a strut rod on the motor to keep it from moving to the rear. Have you changed over to s/s springs lately. When you unbolt the rear u joint, how much does your drive shaft slip into the tranny ?
have motor plate and mid plate and two strut rods so maybe its was just stressed from many trans brake launches
