Re: Boring a 440 and temperature change
[Re: JohnRR]
#1480000
08/06/13 01:24 PM
08/06/13 01:24 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Lean? Timing issue? clogged passages? air bubble?
I'd be looking at these things, a stock 440 engine should idle happily with his setup and a 4 row radiator unless it's 130 degrees ambient temperture. The factory wouldn't have have sent it out the door if the 22" system was not adequate.
x2. If the timing is retarded it will be hotter especially on a new engine. Try giving it another 5-10° of initial timing, set up the ignition curve, and readjust the mixture settings. Sounds like retarded timing to me.
[Re: THESHAKERPROJECT]
#1480002
08/06/13 09:38 PM
08/06/13 09:38 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The modifications to the motor I would not constitute as major "souped" up.... When the car gets back from the body shop, I will get back to it and I do like the idea of a high flow thermostat with a 165 opening temp ( or there abouts ).... We will order a pusher fan, similar, if not, the same one on the previous reply ( thanks by the way, it is like the one on my Daytona ). The ignition timing I can't remember off the top of my head, but I know it isn't extreme. There's no vacuum advance since this is a MSD system ( including the billet distributor ). The carbs are fresh reman's from Holley. I'll check a plug or two to see about mixture. The 22" with the .030 overbore should be fine... We just have to clear the cobwebs... All good input fellas, thanks.... PS: Regarding the water wetter and distilled water "Bandaid", it worked like a charm on my Daytona.....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1480003
08/06/13 11:36 PM
08/06/13 11:36 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I've posted this before,the 440 in my 62 wagon is .030 over,Isky cam,4 core 22" radiator,6 blade A/c pump,fixed 7 blade fan,shroud,180* thermostat,has never seen anything above 195* ever regardless of ambient temp,will idle as long as I let it and never goes above 185* at the thermostat housing checked with a gun,and it has A/C. " AND THERE IS NO ELECTRIC FAN "
[Re: 62maxwgn]
#1480005
08/07/13 08:09 AM
08/07/13 08:09 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
You are getting crazy old man , that will never work ... it said so on the internet ...
