Re: P/S box interchange question
[Re: gdonovan]
#1479569
08/04/13 07:49 PM
08/04/13 07:49 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The pitman and idler is longer on the fury then the B-body, the sector size could also be different. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1479570
08/04/13 07:53 PM
08/04/13 07:53 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Ok, the first two are not an issue the last could be a problem unless you had the Fury steering pot correct?
[Re: gdonovan]
#1479571
08/04/13 11:55 PM
08/04/13 11:55 PM
astjp2
Utah and Alaska
I got one from a fury 3 and one from my 68 charger, the sector was larger and the pitman was longer, so I was going to use the long one for fast ratio, but it would not fit with my headers so I got the moog one from Ehrenberger for the small sector box....Tim
