Re: 383 starter size problem
[Re: 64dodge572]
#1476942
08/19/13 12:42 PM
08/19/13 12:42 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
(quote),Talked to Wayne Brewer at the Nats. He gave me the diameter measurements of the correct flywheel. I compared my inspection cover with one of his 10.5 ones and they match, and my bell is alum also. So this weekend I will be pulling the flywheel and then I will also be able to confirm the bell housing. Oh and just for general info he said there isn't any way to put the flywheel in backwards and bolt up the clutch.(quote), Mr Brewer needs to call me,!! Because I have seen flywheels put in backwards,and clutch bolted up!! as well, so yes it can be done ,is done, !! still appears you have the wrong flywheel as well!
Show me a picture of a mopar V8 flywheel bolted up to a crank backwards with all 6 bolts? Can't be done.
Here is Proof Brewers is right. I already posted one side of the flywheel. Here is the other side.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1476943
08/19/13 03:01 PM
08/19/13 03:01 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
One could bolt the clutch on that side , it wouldn't work well but it would bolt one ...
Picture of the starter ?
It looks like the ring gear is in the right p[lace ... photo is a little too close up of the side ... Do you know if that is the original bellhousing to that engine ?
I'm going to have to scare the spiders out from under my dart and get a snails eye view of what the 130 tooth wheel looks like mounted up in there ....
One of the bolt holes on the starter is larger than it needs to be but with the starter snout in the pilot of the bellhousing there really isn't any adjustment so the only thing that may cause this is you have some oddball starter that looks correct or the TIR is HUGE between the bell and the engine.
[Re: JohnRR]
#1476945
08/19/13 04:52 PM
08/19/13 04:52 PM
MOPARMIKE69
Nashville, TN
Don't know if it is an original flywheel. I am going to take the starter and compare to another even though the casting number is correct the gear may be too big?
[Re: JohnRR]
#1476947
08/20/13 09:00 AM
08/20/13 09:00 AM
MOPARMIKE69
Nashville, TN
After talking with Wayne Brewer and measuring the diameter of the flywheel he thinks it should be good. Does make sense when it is the correct diameter. Compared the starter to another one that has been working in another engine. SAME. So it has to be a problem with the bell housing position. Maybe no dowel pins or maybe offsets. Will pull it tonight. After all this I went ahead and took the transmission in to have it gone through. Eventhough the seller told me it was rebuilt it was leaking out of the bottom shift lever. Really can't trust anything at this point.
[Re: MOPARMIKE69]
#1476948
08/20/13 09:49 AM
08/20/13 09:49 AM
Posts: 1,565 tennessee
pushbutton
tennessee
[Re: pushbutton]
#1476949
08/20/13 03:18 PM
08/20/13 03:18 PM
Posts: 2,364 PA
70HemiGTX
PA
[Re: MOPARMIKE69]
#1476951
08/20/13 08:09 PM
08/20/13 08:09 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Even if you pulled the dowels no way would the bell be off that much.The bolts would never line up.If I get to the other garage I have 2 flywheels there that are 130s.I also have the OE bell for a 130 wheel.Rocky
Chrysler Firepower
[Re: JohnRR]
#1476954
08/21/13 09:10 AM
08/21/13 09:10 AM
pushbutton
tennessee
Is not a 513 bell a 11" and a 130 tooth wheel a 10-1/2"? If I have read the other post correctly that's what he has.
No the 513 bell is for the 130 tooth wheel. [/quote
OK. One of Galen's books list a 513 as a 11" bell. I guess in 1970 you use a 10-1/2" clutch in a 11" bell if the book is correct. just trying to figure out what's going on here.
[Re: pushbutton]
#1476955
08/21/13 11:33 AM
08/21/13 11:33 AM
JohnRR
That version of Galen's book is wrong, the 513 is, and only ever was, a bellhousing made to be used with a 130 tooth flywheel.
[Re: JohnRR]
#1476957
08/21/13 01:46 PM
08/21/13 01:46 PM
pushbutton
tennessee
It may very well be wrong but I have a 10-1/2" cast iron bell and a 130 tooth flywheel out of a 64 B Body.
[Re: pushbutton]
#1476958
08/21/13 03:00 PM
08/21/13 03:00 PM
JohnRR
Yes but that doesn't answer the issue that is the subject of this thread.
The specific bellhousing used in a 1970 RR with big blocks AND hemis is the alum. 513 bell, which the OP confirmed is what he has, it takes a 130 tooth wheel ONLY. The 130 tooth wheel accepts the 10.5" pattern pressure plate, there is a scalloped version of the 10.5 pattern plate that accepts a 10.95" clutch disc.
