repro tuff wheel question #147668
11/09/08 08:17 AM
11/09/08 08:17 AM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
what is the wheel diameter? also if adding to a b-body do i need that housing (that looks like a can)that is used on a e-body. thanks.
Re: repro tuff wheel question [Re: birdboy] #147669
11/09/08 01:08 PM
11/09/08 01:08 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
Depending on the manufacturer, (there are several) the diameter can vary from 13-1/2" to 15". The adapter you need is a smooth sided piece made just for A and B bodies to mount the Tuff wheel and the rimblow wheel. I have a few in stock if you need for $50.00 each with free shipping in the USA since you're a Moparts member. Check my site for details.
Re: repro tuff wheel question [Re: birdboy] #147670
11/09/08 01:48 PM
11/09/08 01:48 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
FYI, The diameter of an original Tuff Wheel is 14 1/2"..
Re: repro tuff wheel question [Re: plumbeeper] #147671
11/09/08 01:58 PM
11/09/08 01:58 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
What makes the adapter unique to A- and B-bodies? It appears to be the same adapter as used on F/M/J-body cars.
Re: repro tuff wheel question [Re: In_The_Pink] #147672
11/09/08 02:34 PM
11/09/08 02:34 PM
plumbeeper Offline
plumbeeper  Offline
It very well may be the same adapter. I don't know very much about the later body styles however I'ved heard the Red Express and Warlock trucks have a different shaft spline.
Re: repro tuff wheel question [Re: plumbeeper] #147673
11/10/08 11:06 AM
11/10/08 11:06 AM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
thanks dave, do you take paypal? would you recommend the grant #846? thanks again.
Re: repro tuff wheel question [Re: birdboy] #147674
11/11/08 12:01 AM
11/11/08 12:01 AM
plumbeeper Offline
plumbeeper  Offline
The Grant 846 will fit the original Tuff wheel/rimblow adapter. There's several versions now of the Tuff wheel. The Grant 846 is a nice one, but I don't know if it's the most correct appearing or not. There is one I handled at the Mopar Nats this year that appears to me to be dead on. It was at Dales's Cuda Shop.
Yes, we take PayPal. Thank you for your order.
