I got the disc brake 8.75 under the 84 over the weekend #1476670
07/30/13 10:38 PM
07/30/13 10:38 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
It stops better than ever before!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476671
07/30/13 10:39 PM
07/30/13 10:39 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
what brake setup did you end up using?.
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476672
07/30/13 10:41 PM
07/30/13 10:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
What kit did you use?? Love the graffic...
I am truckless..
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476673
07/30/13 10:45 PM
07/30/13 10:45 PM
scratchnfotraction Offline
ooooh noooo Mr Bill
thats just kool.
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: 340SHORTY] #1476674
07/30/13 10:53 PM
07/30/13 10:53 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Bought on ebag. Listed as mopar 8.75 dana 60 disc brake kit. Is a master power brake kit. Everything bolted right on, only issue was the e brake cables. Was able to use the drivers side one as is after moving the 2 into one bracket back to the rear about 3 or 4 in.I modded the pass side stocker to work.
It uses trans am rotors and caddy calipers. Rotors are drilled and slotted, and drilled for 4.5 bp.
Real happy overall. Was right at 400 to my door.
Thanks 340 Shorty! I have always caught static being named Bill...lol
Just couldnt do a smiley face!
84 D150 440/727
79 /6 swb D150
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476675
08/01/13 12:48 AM
08/01/13 12:48 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Food for thought:
The same seller (Tomsclassic) lists the rotors for 99.00.
I found the caddy rear brake calipers for 95.00
Speedway sells weld on metric caliper brackets for around 22.00 a pair. If ya don't mind waiting for all the stuff to come in seperately, a guy could do it cheaper with welding capability. Then ya would have to figure out e brakes if ya want em, otherwise just use regular gm metric calipers which are cheaper.
The advantages of the kit are:
Everything is brand new
It all bolts on, and ya could change back to drums.
It all comes together, and works like it should.
Time!
I bolted on the kit, old parts disassembly and pulling axles included in less than4 hours.
I spent 2 hours of that on the brake cables.
84 D150 440/727
79 /6 swb D150
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476676
08/01/13 01:54 AM
08/01/13 01:54 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Bill it looks better under the truck than on stands
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476677
08/01/13 12:07 PM
08/01/13 12:07 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Food for thought:
Time!
if you dont want an ebrake you could use an 80's monte carlo front caliper. i forgot what kit did that
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: 72d100] #1476678
08/01/13 02:32 PM
08/01/13 02:32 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Yes, the 80s monte is a gm metric caliper, they used them on most gm cars for several years after 1978.
The caddy rears have the same bolt spacing.
84 D150 440/727
79 /6 swb D150
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: old_goat] #1476679
08/05/13 10:07 AM
08/05/13 10:07 AM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
Did you have to use "green bearings" (the non adjustable type) on the axle shafts?
Re: I got the disc brake 8.75 under the 84 over the weekend [Re: jstollfu] #1476680
08/05/13 09:47 PM
08/05/13 09:47 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
No, stock bearings. You do have to pull the axles to remove the backing plates, and install the spacers that take their place..I readjusted the end play after installing the axles. All is good!
I did install new seals and gaskets.
84 D150 440/727
79 /6 swb D150
