Thanx for the link, but I don't think I will be following this advice. I Read this far and said to myself "What the heck" it says to use the green wire in the first sentence and then the red in the last sentence, on the coil +.
copied from the link.
Quote"
Run the green wire to the positive side of your coil, then cut the wire with diagonal pliers. Crimp an eye connector at the tip of the wire, using pliers. Remove the nut on the coil's positive terminal, plug the red wire onto the terminal and replace the nut."
I figured what the heck and just tried one at a time and nothing for either way. Si as usual I should have opened it up and this is what I found. Looks like I will need to do some soldering first.
new question does anybody remember where all three wires go?
