Factory Gas Tank Tube: Lead coated? #1476276
07/30/13 12:59 AM
07/30/13 12:59 AM
Arizona
69rrgrabber Offline OP
Arizona
69 Charger fender to gas tank tube. Someone had painted mine black and I sanded it to prep for zinc plating when I noticed that it had something like a thin layer of lead on the outer surface. I guess that it helps to avoid sparks, anyone ever heard of this.
Thanks,
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Factory Gas Tank Tube: Lead coated? [Re: 69rrgrabber] #1476277
07/30/13 06:58 AM
07/30/13 06:58 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It is likely Terne Coating, or terne metal. It is a combination of lead and tin coating that was commonly used in fuel tanks and associated components. It is a hot dip application process and very corrosion resistant.
Re: Factory Gas Tank Tube: Lead coated? [Re: BSB67] #1476278
07/30/13 01:44 PM
07/30/13 01:44 PM
Arizona
Arizona
Terne metal, that's a new one for me, but makes sense. I was going to zinc plate the whole part but I'm not about to strip the terne coating which seems well intact despite my wire wheeling the paint off. Too bad the coating does not extend to the filler side that goes under the gas cap. Mine was rusted before I cleaned it up. I'll keep it natural and use the RPM protectant.
BTW, I'm a big fan of your 1st Gen. Big power with exhaust manifolds, I love it!
Re: Factory Gas Tank Tube: Lead coated? [Re: 69rrgrabber] #1476279
07/30/13 02:52 PM
07/30/13 02:52 PM
MD
floyd Offline
floyd  Offline
MD
Previous post on topic. Wilson Productions does a great job on filler tubes.
https://board.moparts.org/ubbthreads/show...t=1#Post6686478
Re: Factory Gas Tank Tube: Lead coated? [Re: floyd] #1476280
07/30/13 07:43 PM
07/30/13 07:43 PM
Arizona
Arizona
Thanks for the post. I checked out his sight and his service of re tinning the part looks like the way to go.
Re: Factory Gas Tank Tube: Lead coated? [Re: 69rrgrabber] #1476281
07/30/13 10:36 PM
07/30/13 10:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I sent mine to Allen and he did a great job. He also did my door, trunk and hood latches also great work.
