Why did the lifters fall out?
#1475461
07/28/13 09:32 PM
07/28/13 09:32 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Took my daughter's car to test and tune last night. Its a street and strip car with a pretty fresh 440. First time out with the headers - car was suffering from bad reversion with the stock 383 exhaust manifolds. Car was inconsistent in mph - 92 to 95 mph in 6 runs. The runs were all with very short time in between the runs. She ran a best ever 14.19 on the 6th run. My wife and I waited in the pits and she did not come back from the run. Bottom line - when she got on the return road the car overheated (not bad - spewed some out of the overflow catch can). She also said the oil light came on and the car died. I do have a fuel cutoff on low oil pressure, so I figured that killed it. When I started it up, it made a little racket and died. I tried again and it was obvious something was wrong with it and we definitely had no oil pressure so I towed it home. Pulled the distributor and had resistance in the oil pump so I pulled the intake. I was not surprised to find a lifter had fallen out. I was stunned to see 2 lifters out (#2 and #4 cylinders). The jam nuts were loose on the Harland Sharp rockers. Somehow I dodged a MAJOR bullet. Seems like no real damage. One pushrod cup is a little banged up - I will replace both pushrods (they are not bent) and I think I will go back to the Crane ductile iron rockers. So why would 2 rockers loosen up? How could it happen at the same time? Seems too much coincidence to me. I do know preload was on the loose side. Opinions?
Re: Why did the lifters fall out?
[Re: markz528]
#1475462
07/28/13 10:02 PM
07/28/13 10:02 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have had that happen with alum rocker arms, never with the Crane iron rockers. My solution was to replace the jam nuts with ARP 12 point nuts that have a wide flange made on them. Sorta like having a flat washer made on them. This incresses the locking surface of the nut to rocker by a bunch, with out having to over torque the lock nut. You can buy them at Summit in two different wrench sizes (7/16" & 1/2") in packages of ten. Since I went to these nuts, I haven't had one back off. Something else, don't over thighten the jam nut either. This will can cause the nut to get loose or stess the adjusting screw to the point of breaking, and it will break right where the nut meets the rocker, then the top half of the screw and the jam nut will fall off and the rest of the screw will back out. Then the push rod jumps out followed by the lifter and you what happens next. And yeah, I'd say you dodged a big one. Brian
[Re: Cab_Burge]
#1475465
07/29/13 01:40 AM
07/29/13 01:40 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Dan @ performance only cleans all adjuster screws and puts blue (I believe) locktite on them. He did this on a set of rockers I bought from him and to this day, when I have to adjust them, they are snug even when loosened up.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1475466
07/29/13 03:04 AM
07/29/13 03:04 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Make sure the pushrods clear the heads too.
Mopar to the bone!!!
[Re: 72Swinger]
#1475467
07/29/13 02:27 PM
07/29/13 02:27 PM
markz528
Morrow, OH
Well picture is getting clearer.
What I do know is that it looks like the preload was not properly set, and is inconsistent. The push rods are too short and the adjuster studs are not protruding thru the nut (not a good situation for keeping the nuts tight). At least 2 threads in the nut are showing.
Plan is I am sending my Crane ductile iron rockers to RAS to have brass bushings installed. They will also banana groove the shafts. Will get a new set of pushrods once I figure out the correct length for the Crane rockers. Will keep the Harland Sharps for spares for the race car.
I expected the car to go 13.75 in good weather. Friday it went 14.19 (fastest run ever) on the last run. Will be interesting to see what it runs when the valves actually open and close properly. In a very quick inspection found an exhaust rocker not only did not have preload, but had 0.040 lash!
[Re: markz528]
#1475468
07/29/13 02:37 PM
07/29/13 02:37 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
On the pushrod length most of the pushrod makers and rocker arm manufacuters will tell you to shoot for between one and three threads exposed on the adjsuter screw under the rocker arm body That works real well for me
[Re: markz528]
#1475470
07/29/13 03:17 PM
07/29/13 03:17 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I hope you aren't in a rush, I've heard of long wait times lately.
[Re: markz528]
#1475474
08/17/13 12:58 AM
08/17/13 12:58 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Well they are done and in transit! I will keep you posted!
Can I ask how much that cost?
[Re: Quicksilver440]
#1475475
08/17/13 01:32 AM
08/17/13 01:32 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
We can bush & radius the tips for $15.00, $6.00 extra for new adjusters & 12 pt nut.
I emailed them on monday about bushing a set of TA rockers and Tuesday they responded with the above price...to give ya an idea.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: markz528]
#1475476
08/17/13 11:28 AM
08/17/13 11:28 AM
JohnRR
U.S.S.A.
How long was the wait time ?
[Re: 70AARcuda]
#1475478
08/19/13 07:12 PM
08/19/13 07:12 PM
Quicksilver440
Central Valley, CA.
Thats really not too bad.....I'd like to have my cranes done.
If someone can post pics of the finished product...it would be greatly appreciated. I'd also like to see the "radius the tips"....I'm interested in how they accomplish that.
[Re: markz528]
#1475481
08/20/13 05:54 PM
08/20/13 05:54 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Can happen with hydraulic lifters.. Usual problem is the lifter pumps up due to some garbage buildup in its bleeder hole.. Pressure builds and blows out the pushrod, then oil pressure drops qwickly once the lifter is out of the hole. Just my $0.02...
