would a 1988 ram truck be a good donor?? #1474879
07/27/13 04:20 PM
07/27/13 04:20 PM
mn
flyman Offline OP
flyman  Offline OP
mn
I am looking for a good donor motor for a rod project. I have a chance to buy a 1988 ram truck motor and trans. I know it has roller lifters. But I don't know muck about the heads etc. on that motor Good choice or no?
Re: would a 1988 ram truck be a good donor?? [Re: flyman] #1474880
07/27/13 09:25 PM
07/27/13 09:25 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Sorta: Not a powerhouse in stock form but a cam grind, headers and intake swap will wake it up. A 360 magnum is a lot more powerful if you can find one with usable heads. I think the 88 is a 3 speed non overdrive as well. Any 360 Magnum automatic will be an overdrive 4 speed automatic.
Sheldon
Re: would a 1988 ram truck be a good donor?? [Re: RUNCHARGER] #1474881
07/28/13 03:35 AM
07/28/13 03:35 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
nothing wrong with the 88 motor if u want a nice dependable driver, the roller cam is just an added plus if you rebuild it and are worried about cam break in,, the trans is probably a low 1st gear 904 ,, usually called a 999 i have one in my 40 dodge good combination for a rod,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: would a 1988 ram truck be a good donor?? [Re: flyman] #1474882
07/28/13 05:16 AM
07/28/13 05:16 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I bought a new 1988 3/4ton(my first new vehicle) and it ran great with just a little 318. My only complaint was it's top speed was only 87mph.. going down hill.
I miss that old truck
Re: would a 1988 ram truck be a good donor?? [Re: 52savoy] #1474883
07/28/13 07:37 AM
07/28/13 07:37 AM
mn
flyman Offline OP
flyman  Offline OP
mn
Thanks for the info, Iam thinken magnum with the stock efi. If I can figure the wiring out!
Re: would a 1988 ram truck be a good donor?? [Re: flyman] #1474884
07/28/13 01:09 PM
07/28/13 01:09 PM
RUNCHARGER Offline
RUNCHARGER  Offline
The Magnum and overdrive is superior. You can convert it to a carb easily or there is a fellow on Moparts that can set you up with a plug and play harness if necessary. If you get a donor vehicle it's pretty easy to make it run, really there are only a handful of wires that need hooking up and then figure the fuel delivery system out.
Sheldon
