TCS Billet high gear Drum #1474644
07/27/13 12:35 AM
07/27/13 12:35 AM
usa,pa
jkwedge540 Offline OP
usa,pa
Just got a TCS billet 727 High Gear drum From John Cope. I took it apart and found 4 little red rubber pieces of tubing on all the steels. does anyone no if you leave these in or take them out?
Re: TCS Billet high gear Drum [Re: jkwedge540] #1474645
07/27/13 03:14 AM
07/27/13 03:14 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
ring John, go to the horses mouth.
Re: TCS Billet high gear Drum [Re: rebel] #1474646
07/27/13 09:08 AM
07/27/13 09:08 AM
usa,pa
usa,pa
How do you get a hold of John Cope on Saturday?
Re: TCS Billet high gear Drum [Re: jkwedge540] #1474647
07/27/13 09:10 AM
07/27/13 09:10 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
id like to see a pic,mine aint got no rubba.
Re: TCS Billet high gear Drum [Re: bonefish] #1474648
07/27/13 09:15 AM
07/27/13 09:15 AM
usa,pa
usa,pa
They look like 14 gauge wire covering.
Re: TCS Billet high gear Drum [Re: jkwedge540] #1474649
07/27/13 09:28 AM
07/27/13 09:28 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
That is to reduce friction of the clutches when not applied. A & A does that also.
Leave them in...
Re: TCS Billet high gear Drum [Re: 340_Dart] #1474650
07/27/13 11:59 AM
07/27/13 11:59 AM
Dyno1 Offline
Dyno1  Offline
the rubber is in all Pro Trans 727's
Re: TCS Billet high gear Drum [Re: Dyno1] #1474651
07/28/13 01:10 AM
07/28/13 01:10 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
HUH my TCS billet drum didn't have any rubber pieces in it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: TCS Billet high gear Drum [Re: dusturbd340W5] #1474652
07/28/13 01:46 AM
07/28/13 01:46 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
they are cut O rings and I hope you did not mess up what I had done.
