Re: 440 Intake manifold gasket
[Re: tuff440]
#1473897
07/28/13 11:51 AM
07/28/13 11:51 AM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Out of curiosity, does anyone make a valley plate which works with e-heads.
I believe the ones that work with Indy heads will work with the Edelbrocks. When I had my block decked, I failed to have them machine the end rails, so the plate won't work on mine.
Brian
[Re: tuff440]
#1473899
07/28/13 08:17 PM
07/28/13 08:17 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I got that part number mixed up. The FEMS96000 says its for stock to mild engines and the 1215 is the embossed steel laminate version which has the 4 paper gaskets Brian mentioned. They are both a bath tub design which look identical which is why I asked about the two different gaskets. I will buy the 1215. Out of curiosity, does anyone make a valley plate which works with e-heads.
what you are reading as a steel laminate version is a screwed up description as you have found out. The 1215 is the bath tub with the blocked heat riser , since the RPM heads don't have a heat riser that really does not matter. the gasket is sold wit ha set of the 4 .030 thick fiber gaskets , use them or don't , it's your decision.
I think Andy F makes a valley cover that works with the rpms , Check mancini , they sell his parts.
