Re: Torsion Bar removal tool? [Re: GTXKen] #1473455
07/25/13 01:17 PM
07/25/13 01:17 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Mickey mouse has removed every single torsion bar it's ever come up against.
Re: Torsion Bar removal tool? [Re: RobX4406] #1473456
07/25/13 01:51 PM
07/25/13 01:51 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Then you have been very fortunate, and lucky, but some day your luck will run out.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Torsion Bar removal tool? [Re: hemi71x] #1473457
07/25/13 02:02 PM
07/25/13 02:02 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
I also have one of those factory Miller Special Tools, torsion bar removal tool.
It's a heavy duty, well manufactured tool, for the removal of some really stuck toesion bars.
Without that tool i wouldn't have been able to get some bars out of cars, that i had to work on at the shop, or wrecking yards.
Yes, sometimes the home made, Mickey mouse, tool may work for you, but in a lot of instances they won't.
And by the way, the Miller tool uses big,1/2 diameter bolts, and not 1/4 inch, like one other poster wrote about, for his tool.
Have no idea where he came up with that kind of measurement.
Mine has been beat on many times, to get stuck bars out out their mounts.
Same, and I am pretty sure you can still order it from Miller. although the last time I priced it it was $85 or so.
Re: Torsion Bar removal tool? [Re: krisiesmopes] #1473458
07/25/13 02:07 PM
07/25/13 02:07 PM
RobX4406 Offline
RobX4406  Offline
It's not surprising why many choose to post less and less at this place.
Re: Torsion Bar removal tool? [Re: Commando1] #1473459
07/25/13 02:11 PM
07/25/13 02:11 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I have been making them for years. They are made from 1"X 1" steel with a knurled handle. .The tool uses 4 contact points to clamp on the bar (the factory tool only has 3. Also the tool has 2 3/8 grade 8 bolts instead of the factory 1/4 inch bolts. I have them available here http://www.custommachinecomponents.com/shopdisplayproducts.asp?page=3&id=8
I'm going to simply say this. Your tool worked for me when all the DIY Mickey Mouse methods were just a waste of time. My T-bars were IN THERE!!
Nice product. Thanks.
BTW, I learned something when using this tool. You really, REALLY (!!!) to need to crank down on the bolts to way beyond the tightness you think you need. Those GR 8's can take it. Then it works like a charm with the handy old BFH.
Bought one off Ebay. Just slid up and down the torsion bar, never even budged it. Couldn't tighten it enough. Makes a good paperweight to hold instructions.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Torsion Bar removal tool? [Re: RobX4406] #1473460
07/25/13 02:17 PM
07/25/13 02:17 PM
hemi71x Offline
hemi71x  Offline
Sure doesn't look like you have cut back any, with 11,000 + postings.
Re: Torsion Bar removal tool? [Re: hemi71x] #1473461
07/25/13 02:27 PM
07/25/13 02:27 PM
RobX4406 Offline
RobX4406  Offline
What's the distribution?
I'll stick with my home made tool that works for me. I don't need to rely on luck.
Re: Torsion Bar removal tool? [Re: OhioMopar] #1473462
07/26/13 09:08 AM
07/26/13 09:08 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
That is why I emphasized:
"You really, REALLY (!!!) to need to crank down on the bolts to way beyond the tightness you think you need."
You only "thought" the bolts were tight enough...
Re: Torsion Bar removal tool? [Re: Commando1] #1473463
07/26/13 06:13 PM
07/26/13 06:13 PM
Sac, CA
mopowers Online confused
mopowers  Online Confused
Sac, CA
Penetrating oil is your friend!! Unload them, make a simple tool and pound away!! No need to spend $50 on a special tool. Make your own! It's easy and more rewarding. Spend the $50 on gas for when the car's cruisable again.
