which sb intake gaskets to use #1473255
07/24/13 10:18 AM
07/24/13 10:18 AM
Harrisburg Pa. 17112
moparmikethree Offline OP
Doing the Magnum heads on a LA 360 block. Which intake gaskets to use, LA style or Magnum or does it not matter. I have steel or fiber gaskets. What would you use
Re: which sb intake gaskets to use [Re: moparmikethree] #1473256
07/25/13 02:01 PM
07/25/13 02:01 PM
can't believe i didn't get a reply yet
Re: which sb intake gaskets to use [Re: moparmikethree] #1473257
07/25/13 04:52 PM
07/25/13 04:52 PM
fiber with Permatex "high tack" the red stuff in a spray can. It goes on light/even & is exteremely tacky & holds gaskets in place & seals very well, part # 99MA. As you know the mag ports are smaller (318 sized) so get the right gaskets for your intake choice
Re: which sb intake gaskets to use [Re: moparmikethree] #1473258
07/25/13 07:29 PM
07/25/13 07:29 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Just a standard set of Magnum intake gaskets(grey graphite? material) is all that's needed. Attach the intake gasket to the head,Hi tack or other adhesive,not rtv,discard the end rail gaskets for a bead of RTV.
