Pinion Angle #147244
11/08/08 12:19 PM
11/08/08 12:19 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
My transmission is 4 degrees down and my axle is 5 degrees up, is that ok? I'm trying to track down a vibration in my drive line. I measured from the face of the pininon yoke where the screws go in, and the face of the transmission shaft. Is that accurate? I also have my front end on ramps, and my axle sitting on jack stands. Would this givw me an accurate reading?
Re: Pinion Angle [Re: wtucker] #147245
11/08/08 02:46 PM
11/08/08 02:46 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You should have weight in the drivers seat to simulate the driver. Good info on pinion angle in the archives.
Re: Pinion Angle [Re: bobby66] #147246
11/08/08 03:18 PM
11/08/08 03:18 PM
I think you'd want it on all 4 tires on a level surface for the protractor to give you a correct reading.
