Page 3 of 4 1 2 3 4
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471780
07/23/13 05:24 PM
07/23/13 05:24 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I noticed you have quite a bit of edelbrock stuff on your engine. You didn't specify what timing chain you have but I have seen TWO of the edelbrock chains installed incorrectly due to the dots being vague as to how to align. Both engineers ran ok until 4800 rpm and just wouldn't pull anymore. Sounded like timing and fuel.
Re: 440 falls off at 5 grand...Stumped [Re: dezduster] #1471781
07/24/13 02:20 PM
07/24/13 02:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Silly question, what is the RPM range of the cam???
1. Fuel pressure, easily checked by installing a fuel pressure gauge and making a quick test run. If you're dropping below 6 psi you have to resolve the issue.
2. Try a run without the air cleaner, I got my backside kicked years ago by a big block that had to small of an air cleaner on it. Another similar situation was due to the air cleaner lid being too close to the top of the carb due to hood clearance.
3. Try un corking the motor. A restricted exhaust will drive you nuts. Think, mouse nest, collapsed baffle, heat riser stuck 1/2 shut etc.
4. Valve springs. I am not familiar with the 303 lunati but if it has steep ramps, springs, weak or not will cause the problem. IF that is the culprit it may also be prone to burping gas out of the carb due to the valves floating.(should be apparent with the hood and air cleaner off. One can make a series of test runs to establish the exact RPM that the problem occurs. Install .060 t.125 shims under the springs and repeat the test. IF the RPM moves up you have found the issue.
5. Along shot would be other valve train issues, IE: geometry, rocker arms/ interference, pushrod length etc.
keep us posted
Re: 440 falls off at 5 grand...Stumped [Re: TJP] #1471782
07/24/13 02:25 PM
07/24/13 02:25 PM
dogdays Offline
dogdays  Offline
The Lunati 303 is one of the larger of the Voodoo cams, which have quick ramps. That's why I say springs. The OP didn't build the heads himself so he doesn't know what they are.
R.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471783
07/24/13 02:38 PM
07/24/13 02:38 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
and hemi race springs what ever that means. they are single with dampners.
My buddy had those springs on his '68 Pure Stock Hemi, it fell on it's face at 5,300 RPM's, changed to a different spring, now it will go 6,000 no problem.
Re: 440 falls off at 5 grand...Stumped [Re: Dave Watt] #1471784
07/24/13 04:50 PM
07/24/13 04:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quick ramps require a stiff spring
it would appear as though the springs may be the issue, some of the things I suggested earlier are fairly easy things to check and can definitely cause the problem described. if the two above quotes are factual then the springs are probably at fault.
Re: 440 falls off at 5 grand...Stumped [Re: TJP] #1471785
07/27/13 06:23 PM
07/27/13 06:23 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
I picked up a summit dualfeed line with filter and gauge and a separate line to tape the gauge to the windshield. I got a constant 4 psi with no drop in pressure,engine still falls at 5 grand. I took theline off and installed it to the feed line and get a chatty 6.5 psi. I also replaced the fuel pump rod with a mancini one.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471786
07/27/13 08:44 PM
07/27/13 08:44 PM
Alright it ain't fuel starvation. EDIT got a points or electronic dizzy/system that you can sub in for a test? I feel lucky
Re: 440 falls off at 5 grand...Stumped [Re: Sinitro] #1471787
07/28/13 05:16 AM
07/28/13 05:16 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Obviously you have hydraulic lifters..
If original Mopar OE stockers 5K or a little over is all you will get...
Just my $0.02...
My 383 had a 292/509 old school purple shaft with stock springs and rockers, and Summit hyd lifters. It would pull hard up to 7200 and would keep going if I didn't shift or back off.
Previous owner used it for bracket racing and would hold it to 8000 on the shifts.
When I first installed the engine it would fall flat at about 4800-5000, mine ended up being a bad carburetor. I switched from the Holley it came with to a new Eddy 750 and wow, that woke it up.
Latter added the tunnel ram and a second Eddy 750 and I couldn't stop giggling.
But it seems the OP had determined its not a fuel issue.
Re: 440 falls off at 5 grand...Stumped [Re: hp383] #1471788
07/28/13 05:41 AM
07/28/13 05:41 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Just my $0.02...
The usual.. mopar valve spring bashing
I ran the same set of mopar "purple stripe" springs for 4 seasons, 3 or 4hundred runs. Shifted the Hemi at 6200 and trap rpm was about 7200! oh, rear gear ratio was 5.50
I still have those spring and they carry the same pressure 35 years later. Also a few more new sets and I compared seat and open pressures on every set. They were indentical.
I guess I bought the only good sets that came out of Performance Parts.
I had a 383 built by Mid West Balancing(Performance Research now) in the early 70s and it would tach over 8,000 with the magnum "red springs". The bad thing is the valves couldn't take it and I broke a few... my bad
My roadrunner.. same set of MP street Hemi springs since 1988 and its still pulling hard at over 7,000rpm.
Re: 440 falls off at 5 grand...Stumped [Re: 52savoy] #1471789
07/28/13 07:52 AM
07/28/13 07:52 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
And mine (springs recommend by MP) had lost 50% of its rated pressure in a week as did the next set. I wasted hundreds of dollars chasing the problem not to mention track time and more $$$ towing too and fro.
Good luck with your springs, russian roulette if you ask me.
Re: 440 falls off at 5 grand...Stumped [Re: gdonovan] #1471790
07/28/13 12:30 PM
07/28/13 12:30 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I can't vouch for what's sold now.
My springs have proven themselves by lasting all these years on nothing less than .600 lift. What else can I say other than I'll run them as long as the pressures stay up.
1970s and counting
As far a motor not revving...I agree with you guys. It can be gas delivery(pressure or adjustments), timing, valvetrain and possibly internal engine.
I'm a big fan of common sense..I would never jump to the conclusion it's springs before eliminating other potential problems first
Re: 440 falls off at 5 grand...Stumped [Re: 52savoy] #1471791
07/28/13 01:33 PM
07/28/13 01:33 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Which I already pointed out, taping a fuel pressure gauge to the windshield and going for a ride would eliminate the fuel pump as a possible issue.
Cheap stuff first.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471792
07/28/13 02:15 PM
07/28/13 02:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I would verify the needle and seat are correct. There is a certain size needed to allow enough fuel to enter the bowls. If to small you may be starving for fuel even though you have pressure. Pressure is flow to resistance.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471793
07/28/13 02:51 PM
07/28/13 02:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Ok, Lets assume fuel pressure is OK.
Does it drop at the same RPM in a 3 gears???
1. try the air cleaner off, (been bit twice by that, and its a kwik test,
2. if your running Chrysler electronic ignition you can try another control box, (long shot but again cheap and kwik)
3. next, I would try uncorking it,
4. valve spring time
Re: 440 falls off at 5 grand...Stumped [Re: NITROUSN] #1471794
07/28/13 10:34 PM
07/28/13 10:34 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
I've thought of this but not checked into it yet.bought a used carb and rebuilt it with a fast kit. I still think it's a fuel issue,car dose not sputter or pop,just sounds like running out of fuel. cant find info on what size needle seats are used.???
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471795
07/28/13 10:51 PM
07/28/13 10:51 PM
I had a stock (rules required) airtex mech pump on a circle track 360 (9:1CR, 2bbl) with 5/16 line & there was NO delivery issue at WOT at 6300 RPM at the end of the straights. I'd sure think a DP holley would not have inadequate needle/seat sizes. Stay on this & keep us updated as we are anxiously awaiting the outcome
Re: 440 falls off at 5 grand...Stumped [Re: RapidRobert] #1471796
07/28/13 11:45 PM
07/28/13 11:45 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
chased a fuel issue before because I did not have a gauge to check it.[ get one]. after changing almost everything that could be changed , I looked at the fuel pump - PUSH ROD - and it was worn off just enough to deliver some fuel !!
Re: 440 falls off at 5 grand...Stumped [Re: ek3] #1471797
07/29/13 12:17 AM
07/29/13 12:17 AM
K
karmakritters Offline
K
This sounds like the same issue I was having with my 440 last year. Check the rotor phasing in the distributor. My truck would pull hard to about 4500 rpm and then act like it was hitting a rev limiter. Turned out at idle the rotor was firing in the proper spot. Once the rpm's came up it would get farther off until it caused a mis-fire.
Re: 440 falls off at 5 grand...Stumped [Re: karmakritters] #1471798
08/04/13 06:46 PM
08/04/13 06:46 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Did you solve this problem yet?
Re: 440 falls off at 5 grand...Stumped [Re: 68CoronetRT] #1471799
08/05/13 12:38 AM
08/05/13 12:38 AM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
tried .120 needle valve seats.car dose not fall on it's face anymore but still breaks up just past 5 grand. I'm ready to move on to the valve springs now. the question is will the comp 911 springs work with the 303 cam or just order the Lunati spring kit? I can stop by Mancinnis and get the 911 springs on my way to work.
Page 3 of 4 1 2 3 4
