Page 1 of 4 1 2 3 4
440 falls off at 5 grand...Stumped #1471740
07/21/13 10:16 PM
07/21/13 10:16 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
I have a 440 in a e bod,lunati 303 cam,worked 452 heads,391 rear auto.
has 3/8 sender,fuel line,eddy mech. pump,eddy rpm intake,850 holly dbl. pumper msd 6a ign.,headers,2 1/2" exhaust. runs like a champ and falls apart just a tic past 5 grand. I've tried jetting,timing,fuel pumps,no air cleaner,gas cap,2 different dizzy's all with the exact same results.
I would think it should pull past 5 grand but cant figure what's hanging it up. seems to be fuel but plugs are a nice tan color.
Any idea's??? I'm stumped.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471741
07/21/13 10:23 PM
07/21/13 10:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Not knowing whether you've performed the mods to the car, or purchased it that way?....but any chance the MSD may have a 5000 RPM rev chip limiter?
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471742
07/21/13 10:24 PM
07/21/13 10:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
May be running out of fuel. run it up to 4800 let off completely then back to the boards if it then pulls up to say 5500 then you know your fuel is not keeping up!
Re: 440 falls off at 5 grand...Stumped [Re: DAYCLONA] #1471743
07/21/13 10:27 PM
07/21/13 10:27 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Oh yea try different chips if it as a limiter.
The other thing that can cause that is too much preload on the lifters and it pumping open. you can try taking a 1/2 turn at a time out of adjusters to see what it does don't be afraid of a little ticking!
Are the heads milled and or block decked much?
Re: 440 falls off at 5 grand...Stumped [Re: Dodgem] #1471744
07/21/13 10:29 PM
07/21/13 10:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've got a stock 440 magnum that drops dead at 4500,... .
Re: 440 falls off at 5 grand...Stumped [Re: Dodgem] #1471745
07/21/13 10:36 PM
07/21/13 10:36 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
heads been cc'd to 85 so a little cut,can see the numbers shaved a little bit. no rev limiter. didn't think of backing out and hitting it again but will try. just running stock rockers for now.
I did not build the engine so not much help there.
maybe a set of rocker shaft shims???
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471746
07/21/13 11:10 PM
07/21/13 11:10 PM
As you know I'd want to pin it to fuel or ign first. Sounds like you have a killer fuel delivery system but I'd T at the carb inlet & run a neoprene line to a vac gauge with a psi side & tape it to the windshield & need several psi at the offending rpm/load. since you've been dealing with this for awhile I'd go ahead & go to the trouble of subbing in a regular electronic ign & see what happens. Is rotor phasing close enough? NAPA has an Echlin rotor with a .060" longer blade that doesn't fix phasing but helps it as it reduces the distance the spark has to jump. MO-3000 for $8 dollars & change out the door. As said check preload. I'm gonna WAG that it is the Might Sputter & Die system. Holler how it goes.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471747
07/21/13 11:28 PM
07/21/13 11:28 PM
Uranus
strokerchall Offline
Uranus
do you have a carb spacer?
maybe the fuel is boiling?
Re: 440 falls off at 5 grand...Stumped [Re: strokerchall] #1471748
07/21/13 11:58 PM
07/21/13 11:58 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
no and doudt it.
don't think its pre load or pump up.engine runs great until the 5 grand mark and after it falls flat.
Re: 440 falls off at 5 grand...Stumped [Re: Dodgem] #1471749
07/22/13 12:21 AM
07/22/13 12:21 AM
Posting from 1893 in NW FL
TheBlueBeast Offline
I had a 383 that did this. the pump push rod was worn and when i replaced it the problem vanished.
Re: 440 falls off at 5 grand...Stumped [Re: TheBlueBeast] #1471750
07/22/13 12:30 AM
07/22/13 12:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have had a bad coil cause this kind of trouble.
Re: 440 falls off at 5 grand...Stumped [Re: stumpy] #1471751
07/22/13 02:11 AM
07/22/13 02:11 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Cam timing? My son had a 2.2/TII that was a tooth off on the cam sprocket. Engine ran GREAT except above 5,000 or so.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471752
07/22/13 03:22 AM
07/22/13 03:22 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Obviously you have hydraulic lifters..
If original Mopar OE stockers 5K or a little over is all you will get...
Just my $0.02...
Re: 440 falls off at 5 grand...Stumped [Re: Sinitro] #1471753
07/22/13 07:06 AM
07/22/13 07:06 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Don't overlook valve springs.
Re: 440 falls off at 5 grand...Stumped [Re: stinger] #1471754
07/22/13 07:12 AM
07/22/13 07:12 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Shims may help try the fuel test first.
That was the first RPM limiter I ran into back in the day next was valve springs.
Re: 440 falls off at 5 grand...Stumped [Re: gdonovan] #1471755
07/22/13 08:52 AM
07/22/13 08:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
that was my initial thought, as he didn't list what springs....for that fast rate cam, you want a spring probably with at least 120# of seat pressure and a 350lb/in rate
2017 Grand Cherokee Overland
Re: 440 falls off at 5 grand...Stumped [Re: patrick] #1471756
07/22/13 09:16 AM
07/22/13 09:16 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
What happens when you rev it with no load (park/neutral)? If it still won't go past 5k then it's almost certainly not fuel supply
Re: 440 falls off at 5 grand...Stumped [Re: patrick] #1471757
07/22/13 09:17 AM
07/22/13 09:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll go with valve springs, if you are running stock rockers and springs it's a wonder it runs at all. Next would be coil although those tend to work until they get hot then they don't work at all. Alsomake sure you are not sucking the choke horn shut.
Coming soon!!!!
Re: 440 falls off at 5 grand...Stumped [Re: Mr.Yuck] #1471758
07/22/13 09:34 AM
07/22/13 09:34 AM
North Central Florida
E
eightlitermopar Offline
E
We had a 383 falling flat like that. It was the fuel pump pushrod. I second or third this opinion. Just looking at the rod you can't tell much of a difference.
I'd change that and see what happens.....
Mopar or no car
Re: 440 falls off at 5 grand...Stumped [Re: eightlitermopar] #1471759
07/22/13 10:23 AM
07/22/13 10:23 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
p
Hook up a gauge and road test, does not sound like fuel to me though. Light throttle in to 5000 and then roll into it. Should have enough fuel in the bowls for a second or two.
Page 1 of 4 1 2 3 4
