Building 440 #1470712
07/19/13 11:33 PM
07/19/13 11:33 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
I'm building a 440 engine, its got a bigger cam. So does it matter if you put the timing chain gears 4 degrees advanced notch on the gear.
Re: Building 440 [Re: moon] #1470713
07/19/13 11:52 PM
07/19/13 11:52 PM
Depends on the cam but generally it will give more lower RPM power at the expense of higher rpm power. It will decrease valve to piston clearance on either the intake or the ex valves (not sure which). will make it more likely to ping at lower RPM's. Will want a timing change (if you want it spot on). All (except VP clearance) stemming from the change (increase) in cyl psi. Need more info on the build.
Re: Building 440 [Re: moon] #1470714
07/20/13 10:10 AM
07/20/13 10:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
More details but big cams usually respond well to extra advance up to 7000 after 7500 retarded cams respond.
