Re: big block head question?
[Re: batt2rm]
#1470173
07/19/13 11:20 AM
07/19/13 11:20 AM
RapidRobert
they are garden variety iron open chambered heads. Not sure if they would have hardened seats but I dont think so. What was done to the guides? If you get em mock them up on the block with a couple of head bolts per side lightly snugged with your choice of head gaskets to hold em in position & set the manifold down on a new valley pan to get an idea of how much milling is needed & it'd be better to mill the intake face on the heads rather than the intake itself which if you do that (milling the intake) then the intake only fits that combo. between the milling & the gasket thickness & the deck height which could be anywhere you need to mockup & see where you're at & go from there & if the block decks are straight you could use steel shim gaskets with aluminum spray paint as you need all the compression you can get (which wont be much). Talk to Hughes about a cam. EDIT If you are going with an iron OE intake it might be appropriate to install/torque the heads then mockup the intake & mill the intake instead since it ain't likely you'd be swapping an iron intake to another eng somewhere on down the line but it would be recommended to check flatness on the heads' intake surface & the intake as warped surfaces are the cats' ass & very common & vac leaks are a real pain to diagnose/fix
[Re: batt2rm]
#1470176
07/19/13 01:25 PM
07/19/13 01:25 PM
dogdays
Don't waste your money.
First of all, what is the casting number of your existing heads?
Second, have you tried to buy a 3/8" reach gasketed plug at your local WalMart lately? It's harder to buy such a plug than it is to buy one of the plugs I am assuming your heads use. The 3/8" reach tapered seat plug was used on millions of smallblock chevies, among others, and are everywhere.
Third, the ports and combustion chambers on your existing heads are the same as the 346s. Same low-flowing ports, same horrible combustion chamber.
Fourth, you are 1/3 of the way to a set of Stealth heads from 440Source, which will make a real difference in how the engine runs.
Fifth, 0.020 is nothing. So if you DO decide to buy the heads, using a composition 0.040" gasket will have the head exactly where it would be if it had not been milled and you used the stock steel shim gasket.
R.
[Re: batt2rm]
#1470180
07/21/13 01:04 AM
07/21/13 01:04 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
thanks for the help the heads have the hardened seats and bronze valve guide liners. The reason I am thinking about changing are the motorhome heads are unique one year only and take different sparkplugs than the normal big block heads.
If this is a 77 440 then it likely has the 452 heads which are a match for the block in that they have the extra water passage around the spark plugs that aid in keeping them cool. The different plugs you mention are actually a good thing, in addition to what was already said about there being multiple plugs available, the plugs take a smaller socket which makes getting them in and out easier, especially with headers, and the hardened exhaust seats are a plus too. According to the books, they also flowed nearly as well as any factory head put out. Hard to go wrong with them. If I were looking for a set of iron heads the 452's are the ones I'd look for. My .
[Re: StrokerPost]
#1470181
07/21/13 07:25 AM
07/21/13 07:25 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
452 castings came with Hardened exhaust seats and will flow great with a even a mild bowl port.
