DUSTER PROBLEM ....HELP.... #146971
11/07/08 09:04 PM
11/07/08 09:04 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
Im having a problem with my 73 duster,318,auto.Its an off and on problem that seems to get worse and worse.Car runs but acts like im blocking off the carb or something,no power and bogs down and will start to die.car has edelbrock 600 carb.Entire ignition system is new,new fuel pump,etc...cant figure it out??????
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146972
11/07/08 09:11 PM
11/07/08 09:11 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
check the back pressure of the exhaust. maybe the muffler collapsed inside?
Re: DUSTER PROBLEM ....HELP.... [Re: 1965_PLYMOUTH] #146973
11/07/08 10:28 PM
11/07/08 10:28 PM
so cal,cali
so cal,cali
has duel exhaust,exhaust coming out of both sides
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146974
11/07/08 10:37 PM
11/07/08 10:37 PM
NW/Indiana - Chi town
ricomondo Offline
ricomondo  Offline
Possibly the elec. ignition box?
When they start to go, the car will run intermittenly, then die out. Finally, it wont start at all.
GY3 71 Demon 340
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146975
11/07/08 10:37 PM
11/07/08 10:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Could be alot of things but kinda sounds fuel related, may have a section of rubber fuel line coming apart internally blocking fuel flow..Or a partially plugged steel line or the filter in the tank... When it acts up are you able to make it act up with the car out of gear? If so diagnoisis will be easier..When it does it does the engine just shut off or does it start to die while the throttle is open but recover with the throttle closed? If when it acts up does going to wide open throttle cause it to backfire through the carb??
Re: DUSTER PROBLEM ....HELP.... [Re: 1_WILD_RT] #146976
11/08/08 12:34 AM
11/08/08 12:34 AM
so cal,cali
so cal,cali
sometimes while driving it will start running like i was pushing on and off the gas even though i have the pedal steady??
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146977
11/08/08 12:41 AM
11/08/08 12:41 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Is this the #1506 carb with the electric choke? If so, the choke on this carb can be fussy in my experience, and requires some fine tuning.
Re: DUSTER PROBLEM ....HELP.... [Re: In_The_Pink] #146978
11/08/08 12:44 AM
11/08/08 12:44 AM
so cal,cali
so cal,cali
its an edelbrock 1406
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146979
11/08/08 12:51 AM
11/08/08 12:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Like a slight to moderate change (AKA surging) or a running down the road then loses power slows & suddenly regains power kinda on & off the gas feeling??? The first one describes a lean surge, the second could be a plugged fuel supply or an ignition problem...
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146980
11/08/08 12:55 AM
11/08/08 12:55 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Sorry, that's what I should have typed.
Is the choke hooked up? (i.e. hot 12V power to it not from the ignition coil?)
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146981
11/08/08 10:16 AM
11/08/08 10:16 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Sounds like fuel restriction or possibly the fuel pump is sucking in air from somewhere.
I had a cracked 6" fuel hose coming off of the gas tank that caused me grief like yours for several weeks. It didn't leak gas but sucked in air. Replaced it with fuel injection hose and problem was solved.
If the carb and fuel pump are new or in good shape go over your fuel line back to the tank and your fuel sending unit in the tank.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: DUSTER PROBLEM ....HELP.... [Re: MY340] #146982
11/08/08 10:40 AM
11/08/08 10:40 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Try to drive it without the gas cap on the filler. Could be a tank venting problem.
Re: DUSTER PROBLEM ....HELP.... [Re: MY340] #146983
11/08/08 11:46 AM
11/08/08 11:46 AM
so cal,cali
so cal,cali
the carb is new and i replaced fuel pump thinking that was problem but no change......my duster does one thing that none of my other mopars do,when i let it set for more than a week it wont start(dosent get no gas),just turns over,i have to use starting fluid to get it going then once it startes it will run and start on its own???
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146984
11/08/08 12:47 PM
11/08/08 12:47 PM
so cal,cali
so cal,cali
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146985
11/08/08 01:43 PM
11/08/08 01:43 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Does the car actually die? Will it restart after it dies, or does it have to sit for a bit, before it will restart? Can you put in a fuel pressure gage inbetween the pump and carb, and see what kind of pressure you have before it dies. Then immediately after it dies, run around front, pop the hood, and check it again? This will prove what is right and what is wrong to start with, in your fuel system, but nothing about your electrical. (sorry, hope it points you in the right direction to get started.)
A True Hybrid: Burns Gas AND Rubber!
Re: DUSTER PROBLEM ....HELP.... [Re: fastnos] #146986
11/08/08 02:37 PM
11/08/08 02:37 PM
so cal,cali
so cal,cali
well,i got under it and rubber fuel line off gas take was shot,so i replaced it with new line,there is another line coming out of tank,it has a short hose that has been plugged off,where is that supposed to go????
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146987
11/09/08 05:39 PM
11/09/08 05:39 PM
so cal,cali
so cal,cali
there are 2 lines coming out where the sending unit is,one goes to gas line,what is other for??
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146988
11/09/08 05:48 PM
11/09/08 05:48 PM
Central ILL.
twister6 Offline
twister6  Offline
Central ILL.
probably a vapor line that ran back to a charcoal canister
2003 Ram3500 Quad4x4 2000 Dodge Avenger 72 Duster 68 Dart GT
Re: DUSTER PROBLEM ....HELP.... [Re: calimoparguy] #146989
11/09/08 05:50 PM
11/09/08 05:50 PM
Upper Midwest
Upper Midwest
that is a vent to the vapor canister. Take the plug out of it and see what happens, Just don't fill your tank too full or it will run out of that tube.
Re: DUSTER PROBLEM ....HELP.... [Re: MoparforLife] #146990
11/09/08 08:21 PM
11/09/08 08:21 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
It almost sounds like a fuel filter to me.
I like the above mentioned idea of a pressure gauge
inline. Most auto parts stores sell a cheapo unit
that splices in the line for under 20 bucks.
