Re: K & N air intake worth it? [Re: 67Dart383] #146960
11/11/08 03:56 PM
11/11/08 03:56 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Re: K & N air intake worth it? [Re: 360view] #146961
11/11/08 09:56 PM
11/11/08 09:56 PM
Columbus Ga
reflections7 Offline
Columbus Ga
don't be suckered
if you check your intake air temperature sensor (IAT)
and manifold absolute pressure sensor (MAP)
just after the KN install
you will find very little gain
and more to the point
if you check IAT and MAP again
at about 2000 to 4000 miles
you will find even that small gain gone
as the small surface area of the KN has plugged up faster.
http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
Bbsthoilguy did a airfilter test and said the K and N was worthless. Shows pics and results ect.
