Re: K & N air intake worth it?
[Re: 360view]
#146961
11/11/08 09:56 PM
11/11/08 09:56 PM
Posts: 2,675 Columbus Ga
reflections7
Columbus Ga
don't be suckered
if you check your intake air temperature sensor (IAT) and manifold absolute pressure sensor (MAP) just after the KN install you will find very little gain and more to the point if you check IAT and MAP again at about 2000 to 4000 miles you will find even that small gain gone as the small surface area of the KN has plugged up faster.
http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
Bbsthoilguy did a airfilter test and said the K and N was worthless. Shows pics and results ect.
