1st time using HVLP painting - couple questions
#146887
11/07/08 05:43 PM
11/07/08 05:43 PM
Posts: 5,660 Flint, MI
Gusteve
I Love the Unicorn Song!!
Flint, MI
Greetings All,
I just bought a cheapo Harbor Freight HVLP sprayer to try and paint the hood of my '68 Charger (rolling and / or spray bombs aren't coming out good). The rest of the car is OK, just the hood is crappy.
Couple questions:
1) Instructions say 40 PSI. Do I set the regulator on my compressor for 40 PSI when the sprayer is operating? or at 40 PSI when not "under load"?
2) How much overspray can I expect? Since I'm just spraying the hood, should I still tarp off everything in my garage that I don't want overspray on? Or will it not be that bad?
3) Will a fan in the garage help with overspray or will that just make it go everywhere?
4) Should I wear a full-out respirator or is just a mask good enough?
Thanks.
(My apologies for posting something that's not related to a Chrysler merger, economic doom and gloom, penguins, or that "Flo" chick from the TV commercial).
Re: 1st time using HVLP painting - couple questions
[Re: Gusteve]
#146888
11/07/08 05:49 PM
11/07/08 05:49 PM
Posts: 1,615 Table Rock Lake Missouri
furious
Greetings All,
Couple questions:
Thanks.
Do you have a regulator at the gun? I do, and set mine at 20-25.
It will still go everywhere, cover up all that you can. I could talk about this until my fingers cramped.
If the fan is moving air to your hood, you will get more dirt in the paint. I usually open the garage door a little, and point a fan out in an exhaust manner.
I buy those disposable 3m masks. Hope it helps.
[Re: Gusteve]
#146890
11/07/08 05:52 PM
11/07/08 05:52 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Greetings All,
Couple questions:
1) Instructions say 40 PSI. Do I set the regulator on my compressor for 40 PSI when the sprayer is operating? or at 40 PSI when not "under load"? At the gun inlet with the trigger pulled wide open, full flow. you'll have pressure loss the longer the line is from the source. You can make an inexpensive cheater gauge and adjust the wall regulator to 40psi at the inlet.
You'll get some, not as much as a pressure pot style gun. If you don't want overspray on stuff, tarp it. Think about the dry dust a can of spray paint gets everywhere.
Depends, You do want some venting otherwise the air has nowhere to go and the suspended paint will travel with the air.
at a minimum wear a respirator, isosyanates are a nasty compound. You may not be real sensitive to the stuff, others are very sensitive. The stuff can kill you. I wear a full respirator hood with fresh auxilliary air pressure
Thanks.
[Re: furious]
#146891
11/07/08 05:53 PM
11/07/08 05:53 PM
Gusteve
Flint, MI
Cheapo $20 - gun, no regulator at the gun itself.
If I set the regulator at the compressor to 40psi, it drops to like 25 when the gun is in use. If I set it to 60psi, it drops to 40 when the gun is in use. I just wasn't sure which was right.
Whoops - I think someone answered that while I was typing this.
[Re: Gusteve]
#146895
11/07/08 08:17 PM
11/07/08 08:17 PM
Posts: 28,604 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
(My apologies for posting something that's not related to a Chrysler merger, economic doom and gloom, penguins, or that "Flo" chick from the TV commercial). Maybe next time you can post something more important You never posted what type of paint you are shooting. Single Stage do as Dave says above! Base/Clear 3 or so light coats it will be dry like shooting a laqure It goes on shiney but dries to a even dry look! The base is just to make the "color" Then the clear as stated above. Any runs can be sanded out of the clear later. So Base/Clear is easy to shoot since you can put on dry color and clear that can be fixed if messed up.To me it is way easyer to shoot Base clear with Metalics than single stage.
