I bought a pin on hood for the Rampage but I turned
it into a bolt on and its working great.. no springs
so I use a prop rod to hold it open.. I have the
prop rod on a heim joint on the one end and the other
end I put a rubber cap on it.. I also put a hole in
the reinforced area in the front for the prop rod to
fit into so it doesnt slip and have the hood crash
down... the rod itself is 3.8 stainless tubing that
I polished on my buffer.... I didnt even have to
pull the hood when I pulled the engine and trans
![](/ubbthreads/images/graemlins/wave.gif)
