Slow motion launch video of my Dart #1468638
07/16/13 12:10 AM
07/16/13 12:10 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
http://youtu.be/hi-of3wkwQE
Sorry about the quality, but it's better than nothing.
Cal tracs
Split monos
leaf spring sliders
Calvert 90/10 shocks up front
Rancho shocks out rear on 5 of 9
Bars just touching, no preload
M/T 3062W 29.5x10.5W, Stiff sidewall, 12.5# of pressure
3400 RPM off the 2 step, converter flashes to 5300
1.46 60 foot
.013 R/T
Tires look like they wad up pretty good, I've tried more pressure and 60 foots aren't as consistent so I brought it back down. Any helpful ideas are welcome.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468639
07/16/13 12:24 AM
07/16/13 12:24 AM
PA
moparacer Offline
moparacer  Offline
PA
Have you tried full stiff on the rear extension yet?
I just put cal tracks on my Barracuda this past week to try them out. Tested it yesterday and first pass I could tell it was too loose on the extension. Went full tight on the extension and it picked up .03 on the 60 ft the next pass.Just have junker comp 3 ways on the rear. I am footbraking it also and you are trans braking it looks like so the hit will be even harder.
Mine is going to like full loose up front with the extension from what I can tell with the few passes I made on a hot slippery track with junk slicks.
60 fts. only varied .004 so they are going to work pretty good I think.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468640
07/16/13 12:26 AM
07/16/13 12:26 AM
WA
JD Dart Offline
JD Dart  Offline
WA
What is the setting on the front shocks or is there any? Looks like it tries to lift the front right away but is being resisted by the shocks then over comes them and lifts off.
Re: Slow motion launch video of my Dart [Re: JD Dart] #1468641
07/16/13 12:38 AM
07/16/13 12:38 AM
Renton Washington
Renton Washington
Front shocks are not adjustable, 90/10 only. Stock front suspension.
I haven't had played with Rear shock adjustment, but I was going to stiffen them up next time I'm testing. As it sits I made 5 runs with 100-130 track temp and it was 1.460-1.468
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468642
07/16/13 01:35 AM
07/16/13 01:35 AM
PA
moparacer Offline
moparacer  Offline
PA
You could also try putting some preload in it to take some of the initial hit out of it. Its hitting the tire pretty hard but since thats a stiff sidewall it might not mind it.
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468643
07/16/13 01:48 AM
07/16/13 01:48 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Nice leave! It looks like your right there, you might try slowing down the extension just a couple clicks and see what happens.
Re: Slow motion launch video of my Dart [Re: loaderpro] #1468644
07/16/13 12:44 PM
07/16/13 12:44 PM
Renton Washington
Renton Washington
Thanks for the ideas guys, I like both of them! I'd like the sidewalls to last awhile, so taking some of that hit out of it would probably help tire life and consistency.
I'll give it a try and report back
-Dustin
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468645
07/16/13 02:12 PM
07/16/13 02:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Get some front shocks!!!
Cool video. Love seeing the car move with the last amber lit.
Re: Slow motion launch video of my Dart [Re: Al_Alguire] #1468646
07/16/13 04:24 PM
07/16/13 04:24 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Looks good to me!
I got told caltacs and transbrakes don't work on short front segment mopars.
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468647
07/16/13 07:18 PM
07/16/13 07:18 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
leave it alone and keep winning those races
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Slow motion launch video of my Dart [Re: RobX4406] #1468648
07/16/13 07:36 PM
07/16/13 07:36 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Looks good to me!
You going to post a link to your buddy?
Tony
70 AARCuda Vitamin C
Re: Slow motion launch video of my Dart [Re: 70AARcuda] #1468649
07/16/13 07:43 PM
07/16/13 07:43 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Looks great to me.. I want 1/2 psi more in the tires..How much more air have you try ? I run 30x10 with tubes at 15psi
Re: Slow motion launch video of my Dart [Re: loaderpro] #1468650
07/16/13 07:46 PM
07/16/13 07:46 PM
Arizona
Chris'sBarracuda Offline
Arizona
Just a bit too much chassis separation.. Tighten the extension..
Chris..
Re: Slow motion launch video of my Dart [Re: VernMotor] #1468651
07/16/13 07:46 PM
07/16/13 07:46 PM
Renton Washington
Renton Washington
I've never tried more than 13#. No tubes for me at the moment. No rim screws either, and yes the tires move.
-Dustin
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468652
07/16/13 08:44 PM
07/16/13 08:44 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
nice vid, upper or lower hole?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Slow motion launch video of my Dart [Re: Stroker Scamp] #1468653
07/16/13 11:55 PM
07/16/13 11:55 PM
Renton Washington
Renton Washington
Lower hole.
Re: Slow motion launch video of my Dart [Re: Triple Threat] #1468654
07/17/13 12:57 AM
07/17/13 12:57 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I think my dad had five hits on these before I raped the Duster of its "factory" suspension..... If you're interested
Re: Slow motion launch video of my Dart [Re: J_BODY] #1468655
07/17/13 01:42 AM
07/17/13 01:42 AM
WA
JD Dart Offline
JD Dart  Offline
WA
Get them Dustin Be way better setup for you!!!!!
Re: Slow motion launch video of my Dart [Re: JD Dart] #1468656
07/17/13 01:55 AM
07/17/13 01:55 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Looks good to me. Gets right back up on the tire.
Yeah, it's got a smallblock.
Re: Slow motion launch video of my Dart [Re: Chris'sBarracuda] #1468657
07/17/13 02:31 AM
07/17/13 02:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris..
EXCEPT... you have too much pre load...
your car comes up and goes left but 4"-6" which will
make you correct and thats time lost... back down
your right bar a little... or ADD to the left
Re: Slow motion launch video of my Dart [Re: MR_P_BODY] #1468658
07/17/13 08:04 AM
07/17/13 08:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats a cool vid. Looks like you have the car working good and winning. Nice going. Ron
