Dome Lamps on Time Delay Relay Wiring? #146842
11/07/08 03:38 PM
11/07/08 03:38 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
I'm trying to set up my van's two dome lamps so that they dim after a short delay (10 seconds or so), exactly like the ignition switch lamp delay option.
My question is this- do I need to use one delay relay per dome lamp, or can I wire it so both lamps are controlled by one delay relay? I plan to use an ignition lamp harness setup for the dome lamps, but I'm not quite sure how to properly wire it.
Black and brown wires are the only two wires running to each dome lamp, with the brown being hot power and the black being the ground wire controlled by the door jamb switches. The van uses four jamb switches if that makes a difference.
Re: Dome Lamps on Time Delay Relay Wiring? [Re: In_The_Pink] #146843
11/07/08 04:40 PM
11/07/08 04:40 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I believe the old relays are a function of current generating heat to make them work not a given time.
If that is correct I would try one relay and see how
much time you get with that. I bought a new relay
for my A body last fall so I know they are readily available.
As for the wiring, should be fairly straight forward. A wiring diagram will give you the pass
through circuit.
Re: Dome Lamps on Time Delay Relay Wiring? [Re: In_The_Pink] #146844
11/07/08 09:28 PM
11/07/08 09:28 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
This sounds interesting as I just got my van back on the road, this would be a great idea.
Re: Dome Lamps on Time Delay Relay Wiring? [Re: RV2] #146845
11/07/08 10:50 PM
11/07/08 10:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I'd give it a shot with the one time delay also...I'm not sure on the rated output of the delay...As stated it's just a metal strip wound with a small wire that heats up and bends away from the contacts...Anyhow it's a cool idea and if it does'nt work you could snag a newer{and probably solid state} unit out of a vehicle and give it a dedicated circuit....
Re: Dome Lamps on Time Delay Relay Wiring? [Re: screamindriver] #146846
11/09/08 08:19 PM
11/09/08 08:19 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
Done this- use the time delay to trip a 10-20 amp relay- the relay then will turn on the dome lamps.
it can do one lamp- after that the contact of the delay is small and will burn out!
Re: Dome Lamps on Time Delay Relay Wiring? [Re: 71_deputy] #146847
11/09/08 09:45 PM
11/09/08 09:45 PM
Milwaukee, WI
Milwaukee, WI
I figured it out this weekend and used one delay relay per dome lmap. I'll try to post a quickie digram for those who may be interested.
Re: Dome Lamps on Time Delay Relay Wiring? [Re: In_The_Pink] #146848
11/09/08 10:07 PM
11/09/08 10:07 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
The diagram would be great! I would love to try this on my van.
Re: Dome Lamps on Time Delay Relay Wiring? [Re: In_The_Pink] #146849
11/20/08 10:06 PM
11/20/08 10:06 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Dont forget us!
Re: Dome Lamps on Time Delay Relay Wiring? [Re: RV2] #146850
11/21/08 02:22 AM
11/21/08 02:22 AM
Milwaukee, WI
Milwaukee, WI
Forget who?
I'll write something up after I take some pics, hopefully this weekend.
Re: Dome Lamps on Time Delay Relay Wiring? [Re: In_The_Pink] #146851
11/21/08 03:14 AM
11/21/08 03:14 AM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
That is very cool!!
