68 B body acceleator cable needed #1468209
07/15/13 12:20 PM
07/15/13 12:20 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I swapped a big block into my 68 coronet, and also added an Edelbrock performer RPM intake. The throttle cable was a bit too short, but I made it work. Well it broke this weekend, and now I need to fix it. My question is if a stock big block throttle cable is longer than a small block cable. Basically would I get away with a stock replacement cable? Or is there something I should be using with the higher than stock intake? Last question is where to buy an accelerator cable?
Re: 68 B body acceleator cable needed [Re: 68Bullet] #1468210
07/15/13 12:21 PM
07/15/13 12:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have one. PM me.
