74 318 fuel pump interchange with 73 340? #146816
11/07/08 12:44 PM
11/07/08 12:44 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Can't seem to build any fuel pressure on rebuilt 340 currently using 318 fuel pump. I didn't think there was a difference other than overall pressure, right now not even a squirt but was running on 318?...
Some people you just can't reach...
Re: 74 318 fuel pump interchange with 73 340? [Re: Suregrip] #146817
11/07/08 01:16 PM
11/07/08 01:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
got gas in the tank? What was wrong with the other pump? Put a rag in the filler and stick a air nozzle through the rag and blow compressed air into the tank to pressurize the tank and get the fuel flow started.
or pour a little gas into the carb and start the engine. Sometimes this speed is all that it takes to prime the pump.
Re: 74 318 fuel pump interchange with 73 340? [Re: MoparforLife] #146818
11/07/08 07:41 PM
11/07/08 07:41 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
If that don't work, how long did it sit since it was on the 318? could have been ready to go then. Dried out and cracked
