Re: Front disc brake conversoin on 66 coronet
[Re: nomore65BelvJim]
#1467775
07/15/13 01:43 PM
07/15/13 01:43 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I used the A bodys on my 65 B body.Then I swapped to the taller late B body spindles.I like them better.Been on at least 6 years now.First conversion was 12 years ago.Going the used Mopar parts is one of the best.Parts can be had anywhere.Rocky
Chrysler Firepower
[Re: bigblk66_coronet]
#1467777
07/15/13 06:59 PM
07/15/13 06:59 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I like the later stuff myself. Need a part, I can go pick it up at the local parts store. Also doesn't hurt that the spindles and so on I've always had laying around on parts car. Buying a kit makes it much easier but it will cost more.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1467778
07/15/13 09:13 PM
07/15/13 09:13 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am using 2006 crown vic stuff on my 68 charger, if you get the bracket made, its a bolt on deal to the stock drum spindles and gives you 12.02 rotors and dual piston calipers. Parts are sourced from any junkyard except the brackets,which I have a drawing for. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
