Re: '69 Charger Driver's Side Door Won't Close
[Re: 69Charger500]
#1467634
07/14/13 01:05 PM
07/14/13 01:05 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Got it!!
Wow, that is a VERY sensitive striker adjustment!!
After tuning it in to where I thought it should be, it still wouldn't work.
Then, I moved it outboard maybe 0.020" and it latched fine!
Mike
i remember going through that with my RR years ago! and before that it was the grease that had turned to concrete inside the latch!
[Re: 69Charger500]
#1467635
07/14/13 02:47 PM
07/14/13 02:47 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Just gotta play with the three screws on the door striker. Are you 100% sure there is the spacer between the door jamb and the latch?
Have you by any chance added door gaskets? I know mine wouldn't close correctly after I put new door gaskets on. You have to really crank those screws down every time you move it otherwise it will jostle around and knock the latest position out.
Does the door sag? If its open, can you lift the end of the door up and down with noticeable play? Maybe the bushings are shot on the hinges
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: 69Charger500]
#1467636
07/15/13 04:39 PM
07/15/13 04:39 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Good Job, never give up..........
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
