Re: A 100 truck advice needed
[Re: earlymopar]
#1467534
07/14/13 01:32 PM
07/14/13 01:32 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
That price seems high to me. I'd expect it to at least have all the parts to get it running at that price. I don't know your Polara, but those tend to be worth more in similar condition compared to an A-100 PU.
I see rust in the ID tag picture. This is THE thing to look for when getting one of these. I'd guess that in WV, you don't have a lot of rust free examples to choose from, but pay close attention to the bed area, especially down low on each side, the roof rail and wheelwells along with the front floor/step areas.
The floor and rear wall are going to have to be fabbed or sourced from a donor. No repop for those. The wall is PU only.
Look over the suspension and steering. They can suck up money repairing. Look over the wiring too, unless you are expecting to replace it all.
It doesn't say if the trans is a /6 or V8. You can swap the guts to a SB or BB main case if you pay attention to interchange. The As only had 727s, no 904s.
Does it have the frame brackets and are they 6 or 8? Those can be a bit tough to source.
It really depends on what your budget and vision of it finished are. If you are just getting it back on the road with modest small block power, the above mentioned items will guide you. If you are doing something wild (air bag suspension, wheelstander, full-on restoration) it may be better to find one already started and further along or more original.
Join us over at vintage-vans for more info and questions. For the most part, stuff can be found just like any older Mopar. It takes searching and some stuff is rare/pricey.
