Re: Lifter pre-load question
[Re: JoesMopar]
#1467389
07/13/13 06:57 PM
07/13/13 06:57 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
If I set the lifter pre-load correctly, does that automatically mean I have the correct valvetrain geometry?
I'll ask the question not asked ... shaft mount rockers or stud mounted rockers ?
Shaft mounted ... NO , the 2 nothing to do with each other on a shaft mounted rocker system.
stud mount , yes and no ...
[Re: Supercuda]
#1467390
07/13/13 06:59 PM
07/13/13 06:59 PM
JohnRR
U.S.S.A.
Isn't that done by the correct length pushrod though? If I have the pushrod length set so that it gives the correct lifter pre-load, how could the geometry not be correct?
Because preload isn't the determining factor in the valve train geometry. Pushrod length is, too long or too short will affect where the nose of the rocker rides on the valve stem. While it is possible to mess up the geometry with a seriously messed up valve adjustment, the correct pushrod length is one that, with proper preload (or lash as appropriate) gives the correct rocker sweep across the valve tip.
This is only true for stud mounted rockers
[Re: JohnRR]
#1467391
07/13/13 07:16 PM
07/13/13 07:16 PM
Posts: 2,782 USA
JoesMopar
USA
[Re: JoesMopar]
#1467392
07/13/13 07:31 PM
07/13/13 07:31 PM
JohnRR
U.S.S.A.
shaft mounted
Preload adjustment will not change valve to rocker tip geometry .
[Re: JoesMopar]
#1467393
07/13/13 07:40 PM
07/13/13 07:40 PM
RapidRobert
With the #1 cyls' cam on base circle (rotor on #1 or 12-12 dot to dot or dampener mark on TDC #1 compression). install a pair of light springs & wipe the tips of that pair of valves with dykem or a sharpie then install the rocker shaft & the pushrods for that cyl. Hand turn the crank thru 2 revolutions back to base circle. Lay a thin 6" straightedge ruler across the valve rails & touch the magic marker on the edge of the ruler to get wet ink on it then move the ruler over till it touches a pushrod & makes a small ink mark on it then unbolt the shaft or unscrew the rocker adjuster if used till the lifter cup is all the way up then slide the ruler over & make another mini mark then measure that distance between the two marks to get your preload. Take off the shaft rockers & check the wipe pattern (post a pic if you can & the amt of preload you have)
[Re: RapidRobert]
#1467394
07/14/13 09:18 AM
07/14/13 09:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
as said, the issue of geometry comes to the rocker sweeping across the valve stem, nothing to do with preload.
you could have adjustable rockers, and pushrods that are too short. you can then adjust the rockers to get you the proper preload, but then your rocker arm is at an angle where it's not going to contact the outside of the valve stem.
**Photobucket sucks**
[Re: JoesMopar]
#1467396
07/14/13 05:58 PM
07/14/13 05:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Justifiable rockers is how you do that. To be honest, I would not worry about preload over proper pushrod length. Preload is, imo, turd polishing on almost all cases. If you can get everything right great, if not and preload is all that is off and you aren't running a national race program you are turd polishing worrying about it.
[Re: notforsale440]
#1467399
07/14/13 06:06 PM
07/14/13 06:06 PM
Posts: 2,782 USA
JoesMopar
USA
how can I possible change the length of the pushrod to correct the geometry without affecting the pre-load?
you cant......... do your rockers not reach the center of the valve stem? or do they reach too far?
not reaching can be cured by shimming the shaft, but this will cause your pushrods to be too short.....
if this is the case, spend a little more and do what I did
I bought hughes adjustable rockers and they center perfectly...... then bought the proper length pushrods......problem solved
I'm still putting the engine together but was looking at this kit:
https://board.moparts.org/ubbthreads/show...e=2#Post7774480
They come with pushrods, but if they aren't the correct length, I didn't want to spend the money and have to buy another set.
I just couldn't wrap my head around how exactly this works.
[Re: JoesMopar]
#1467401
07/14/13 06:17 PM
07/14/13 06:17 PM
Posts: 162 nj
notforsale440
nj
im just wrapping up my build..... hughes was very helpful
I bought the 1.6:1 roller rocker set with shafts; as I said,they center over my valve stems perfectly
they will loan you a solid adjustable lifter and an adjustable pushrod with detailed instructions....
then you mail them back and they will make the pushrods
mic your hydraulic lifter and set the adjustable solid lifter about .050 shorter to simulate the preload
