92 5.2 magnum, timing chain tensioner? #1467310
07/13/13 04:16 PM
07/13/13 04:16 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Did the 5.2 magnum come with one as factory? Are they required/needed?
I'm replacing the factory chain with a true double roller. I have only replaced one other small block chain and that was on a 77 with no tensioner.
Is this some new fangled device, what is its purpose? do small block chains fit to loose or
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 92 5.2 magnum, timing chain tensioner? [Re: hp383] #1467311
07/13/13 05:05 PM
07/13/13 05:05 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
They did not come from the factory with a tensioner. I believe Mopar came out with them mainly for the 3.9 v-6 to quiet the common timing chain rattle issue with them. They can also be used on the v-8s and help stabilize the timing. A good double roller is a better option in my opinion.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 92 5.2 magnum, timing chain tensioner? [Re: 71yelladustr] #1467312
07/13/13 06:42 PM
07/13/13 06:42 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
A double roller is the best choice OEM gears & chain can be up to 6 degrees either way!
