Need help tuning mild 440
#146710
11/06/08 11:14 PM
11/06/08 11:14 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
Ok. I am lost. I have a 71 cuda with a mild 440. 750 holley, mopar dual plane intake, 1 inch spacer, tti 1 7/8 headers with 3" exhaust, 484-282 pulple shaft cam, 3000 stall 727. I cannot get it lean enough at idle. It will pull 9.5in of vacuum in neutral, but drops to between 5-7 in gear. I have a 6.5 power valve. What can I do to get it leaner?? Oh, timing is at about 12 BTD. Thanks!!!
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: Need help tuning mild 440
[Re: Prodart440]
#146712
11/06/08 11:24 PM
11/06/08 11:24 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
Bump the inital timing up to 16º to 18º and have the total timing at 36º to 38º all in by 2500 RPM's. That shoul help your vacuum. Then adjust your carb from there. Always get your timing straightened out first then tune your carb.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
[Re: Blown_Hemi]
#146713
11/06/08 11:28 PM
11/06/08 11:28 PM
Prodart440
Avondale AZ
I would bump the timing, but it pings if I do. I need to get a timing light to see when the total timing comes in. The idle screws are very sensitive. 1/8 turn either way and it doesn't like it. On another note, what kind of vacuum should the vacuum advance port have?? Thanks!!
Aaron
[Re: Prodart440]
#146715
11/06/08 11:57 PM
11/06/08 11:57 PM
Posts: 292 Atlanta
DartGTX
Atlanta
Are the throttle blades closed past the transfer slots on the carb? My setup is very similar and I replaced the std. hyd lifters with crane "fast bleed" lifters. I went from 11" of vacuum @ idle to 13.5...... Total timing to 34 all in by 2500 rpm. Good luck Good luck
[Re: thedriver]
#146717
11/07/08 10:13 AM
11/07/08 10:13 AM
Posts: 531 Virginia
JimG
Virginia
A power valve opening at idle will not cause rich idle.
I'm with 1 Wild R/T in that you need to check t-slot/throttle plate relationship. Drill holes in the throttle plates only as a last resort, after you're sure the timing is where you want it, etc.
Do a search for 68Bullit's post entitled "Holley Rich Idle" or something similar. He had a situation similar to yours and the transfer slot thing is discussed in detail.
What is this carb - a 3310, double pumper...?
[Re: JimG]
#146718
11/07/08 10:38 AM
11/07/08 10:38 AM
Prodart440
Avondale AZ
The carb is a double pumper. The throttle blades are not open too far. I am thinking the powervalve is the issue.
Aaron
[Re: Prodart440]
#146723
11/07/08 12:25 PM
11/07/08 12:25 PM
Posts: 1,261 ILL
mark7171
ILL
you want more timming at idle, so i'd connect it to full vacuum instead of ported.
i dont know what your build "should make" , vacuum wise. with the correct timing more than 9.
the vacuum advance goes away when you give it gas. it wont be the cause of pinging on normal throttling situations. the clowns that hammer it may have some problems...with their "brain".
your mechanical curve will be the culprit of causal throttle pinging.
700 rpms ? thats a big cam in there.
[Re: Prodart440]
#146724
11/07/08 12:26 PM
11/07/08 12:26 PM
Posts: 531 Virginia
JimG
Virginia
If I move the idle mixture screws in at all, the engine wants to die. I think they are set perfect. After reading your link, I am thinking I need more initial timiing. I can put more timing in, but then it pings. I think I need to re-curve the distributor and work on that angle first. I read the article on the distributor slots and am leaning that way.
Hi Aaron:
I'm a little perplexed by the idle mixture screw situation. If you turn the screws in (lean) to the point the engine stumbles, are you still getting the rich condition? That's what's confusing. Sitting here trying to visualize where additional fuel is coming from still makes me suspect the throttle plates are open too far at idle, causing the mains to operate. But you said that's OK, so I'm still confused.
How far open are the secondary blades? Did you look at those when you looked at the primarys? The same thing can happen back there too, and people sometimes overlook it.
You can try dropping your float level some and see how it responds, although that usually affects part throttle more than anything.
Other than that, I dunno...
I agree with checking the timing, certainly, and getting that dialed in, but (again) retarded initial timing usually results in the throttle plates being open too far at idle and...well, we know the rest!
I ran an almost identical engine in my car before I built the current one. 446", piston tops flush with the deck, same cam as you, home-ported 452's, DP4B intake, and a Holley 3310. I was running 16-18* initial timing, 38* total, and it worked well with no pinging. I had to drill 1/8" holes in my primary throttle plates, for what it's worth.
[Re: JimG]
#146726
11/07/08 12:43 PM
11/07/08 12:43 PM
Prodart440
Avondale AZ
I guess I should get the timing figured out before I even decide to play with the carb. I will see what it like on the initial, and figure total from there. So 36* all in by 2500??
Aaron
[Re: Prodart440]
#146728
11/07/08 12:47 PM
11/07/08 12:47 PM
Posts: 531 Virginia
JimG
Virginia
That should always be the plan as long as the carb isn't so far off as to prevent you from messing with the timing!
With stock iron heads, 38* is the mostly agreed upon number.
[Re: JimG]
#146729
11/07/08 01:27 PM
11/07/08 01:27 PM
Prodart440
Avondale AZ
They are mildly ported iron heads. Just the bowl area. Still 38*???
Aaron
[Re: Prodart440]
#146731
11/07/08 07:23 PM
11/07/08 07:23 PM
RapidRobert
If the throttle blades are opened far enough to where you are into the transition slots could the PV being open be making you too rich since you are partly into the main circuit at that point
[Re: 383man]
#146734
11/07/08 11:58 PM
11/07/08 11:58 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Remeber if the P/V diaphram is blown it will pull fuel right into the intake. Ron
Yes it will...
[Re: Blown_Hemi]
#146735
11/08/08 03:11 AM
11/08/08 03:11 AM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
[Re: JimG]
#146736
11/08/08 05:23 PM
11/08/08 05:23 PM
Posts: 292 Atlanta
DartGTX
Atlanta
I completely AGREE with drilling the holes. The 750 DP I put on my car in 2001 has a 3/16th hole in ALL 4 throttle blades. I haven't had to touch it since installation and it idles at 1050 in P/N and 800 in gear. BTW, I used a power valve PLUG to aleviate the chance of EVER having one blow again. Good luck
[Re: 1_WILD_RT]
#146737
11/09/08 10:30 AM
11/09/08 10:30 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yes it will...
Sounded like you needed to know that. Ron
[Re: 383man]
#146738
11/10/08 12:00 AM
11/10/08 12:00 AM
Prodart440
Avondale AZ
So I was playing with the timing the other night, and I forgot to hook up the vacuum advance. The car seemed to run the same, but without the problems of it pinging when I get on it. I set the initial timing at about 12*. I still don't know what and when the total timing is and when it is in.
Aaron
[Re: Prodart440]
#146739
11/10/08 01:59 AM
11/10/08 01:59 AM
Posts: 2,466 Answering the call of the wild
ThermoQuad
whoa nellie.....no matter what you do to the carb ie drill holes etc, the distributor needs a custom curve or this car will not run properly or in simpler language it will be a pig. 18 initial, 32 total, slow advance rate till all in by 2400 rpm. Put the recurved dist back in the car, set the initial at 18 and set the idle at 1000 rpm and adj the mixture screws to the highest vacuum reading. Readjust the idle to 950 rpm and put it in gear and see what happens. When you get to that point please come back and we will help you finish.
[Re: Prodart440]
#146740
11/10/08 09:34 AM
11/10/08 09:34 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
With that cam you don't even need a vacuum advance. I wouldn't worry about initial and have 38* full at 2600rpm. As mentioned before no matter what you do, if you don't have good compression, 3000 stall and 3.91's or better the car is going to be slow out of the hole. Change the PV, drill the throttle plates and re-curve the distrib, set your timing and let us know how it goes.
