Re: Need help tuning mild 440 [Re: Prodart440] #146730
11/07/08 02:45 PM
11/07/08 02:45 PM
Easton, Kansas
Moparmedic440 Offline
Easton, Kansas
I run the same cam in my 440 Roadrunner and feel your pain. First thing take your idle vaccum in gear and divide it by 2 and that's the power valve you need to run, this is off the Holley web site. Get used to a rich idle you can't lean it out enough. This cam needs a 1000 rpm idle, the timimg spec's for this purple shaft is around 32 to 35 degree's at 2200 rpms. You will have to put lighter advance springs and let the distrubator advance manually. Hang in there you will get it.
Re: Need help tuning mild 440 [Re: Prodart440] #146731
11/07/08 07:23 PM
11/07/08 07:23 PM
If the throttle blades are opened far enough to where you are into the transition slots could the PV being open be making you too rich since you are partly into the main circuit at that point
Re: Need help tuning mild 440 [Re: Prodart440] #146732
11/07/08 09:27 PM
11/07/08 09:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
put the cam shaft in the trash can, it's never going to run lean enough. It's bracket racing cam, if you have 9.5 your about on. What is your compression??? 10:1 or more would be best. They are made to run form 3k up. if you keep the 484 get used to stinky low rpm cruises.
Re: Need help tuning mild 440 [Re: Mr.Yuck] #146733
11/07/08 11:54 PM
11/07/08 11:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Remeber if the P/V diaphram is blown it will pull fuel right into the intake. Ron
Re: Need help tuning mild 440 [Re: 383man] #146734
11/07/08 11:58 PM
11/07/08 11:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes it will...
Re: Need help tuning mild 440 [Re: Blown_Hemi] #146735
11/08/08 03:11 AM
11/08/08 03:11 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Bump the inital timing up to 16º to 18º and have the total timing at 36º to 38º all in by 2500 RPM's. That shoul help your vacuum. Then adjust your carb from there. Always get your timing straightened out first then tune your carb.
Re: Need help tuning mild 440 [Re: JimG] #146736
11/08/08 05:23 PM
11/08/08 05:23 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
I completely AGREE with drilling the holes. The 750 DP I put on my car in 2001 has a 3/16th hole in ALL 4 throttle blades. I haven't had to touch it since installation and it idles at 1050 in P/N and 800 in gear.
BTW, I used a power valve PLUG to aleviate the chance of EVER having one blow again.
Good luck
Re: Need help tuning mild 440 [Re: 1_WILD_RT] #146737
11/09/08 10:30 AM
11/09/08 10:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes it will...
Sounded like you needed to know that. Ron
Re: Need help tuning mild 440 [Re: 383man] #146738
11/10/08 12:00 AM
11/10/08 12:00 AM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
So I was playing with the timing the other night, and I forgot to hook up the vacuum advance. The car seemed to run the same, but without the problems of it pinging when I get on it. I set the initial timing at about 12*. I still don't know what and when the total timing is and when it is in.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Need help tuning mild 440 [Re: Prodart440] #146739
11/10/08 01:59 AM
11/10/08 01:59 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
whoa nellie.....no matter what you do to the carb ie drill holes etc, the distributor needs a custom curve or this car will not run properly or in simpler language it will be a pig.
18 initial, 32 total, slow advance rate till all in by 2400 rpm.
Put the recurved dist back in the car, set the initial at 18 and set the idle at 1000 rpm and adj the mixture screws to the highest vacuum reading. Readjust the idle to 950 rpm and put it in gear and see what happens.
When you get to that point please come back and we will help you finish.
Re: Need help tuning mild 440 [Re: Prodart440] #146740
11/10/08 09:34 AM
11/10/08 09:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
With that cam you don't even need a vacuum advance. I wouldn't worry about initial and have 38* full at 2600rpm. As mentioned before no matter what you do, if you don't have good compression, 3000 stall and 3.91's or better the car is going to be slow out of the hole.
Change the PV, drill the throttle plates and re-curve the distrib, set your timing and let us know how it goes.
