Reproduction fuel line help........ please #1466966
07/12/13 04:03 PM
07/12/13 04:03 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
Looking for a reproduction fuel line from the pump to the carb (thermoquad) on a 440.
Searched around the net for this line on any vehicle that had a 440 with a TQ carb but no luck.
Will a line that connects to an AFB or AVS mate up to the TQ?
Or is there a direct replacement somewhere out there?
TIA
Re: Reproduction fuel line help........ please [Re: roadhazard] #1466967
07/12/13 04:48 PM
07/12/13 04:48 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I am using this one from Herbs, about half way down the page. For 400-440 with Thermoquad. Its a little tight near the valve cover but other than that the fit is fine. I also had to tighten and loosen it a few times to get it to seat well with no leaks.
http://www.herbsparts.com/products.asp?cat=722&pg=3
Re: Reproduction fuel line help........ please [Re: roadhazard] #1466968
07/12/13 07:25 PM
07/12/13 07:25 PM
1972 and later 440 had Thermoquads
Re: Reproduction fuel line help........ please [Re: T2R9] #1466969
07/13/13 09:39 AM
07/13/13 09:39 AM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Thanks T2R9
I've looked everywhere but somehow missed Herb's
Your pic was also quite helpful
